Hello friends, I’m using OH2 with raspberry pi 3 and I’ve successfully installed and tested mosquitto (MQTT broker) using “mosquitto_sub/pub” command on rasp’s terminal.
Then I follow this tutorial:
I uploaded his arduino sketch to my NodeMCU v1.0 module (Wifi ssid and password are matched with my home wifi). Here is the result:
It seems like the NodeMCU is able to connect to Wifi but can not form a connection with raspberry MQTT’s broker.
Here is the code:
//ItKindaWorks - Creative Commons 2016
//github.com/ItKindaWorks
//Requires PubSubClient found here: https://github.com/knolleary/pubsubclient
//ESP8266 Simple MQTT light controller
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
void callback(char* topic, byte* payload, unsigned int length);
//EDIT THESE LINES TO MATCH YOUR SETUP
#define MQTT_SERVER "192.168.137.10"
const char* ssid = "P820";
const char* password = "xxxxxxx";
//LED on ESP8266 GPIO2
const int lightPin = 2;
char* lightTopic = "staircase";
WiFiClient wifiClient;
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
void setup() {
//initialize the light as an output and set to LOW (off)
pinMode(lightPin, OUTPUT);
digitalWrite(lightPin, LOW);
//start the serial line for debugging
Serial.begin(115200);
delay(100);
//start wifi subsystem
WiFi.begin(ssid, password);
//attempt to connect to the WIFI network and then connect to the MQTT server
reconnect();
//wait a bit before starting the main loop
delay(2000);
void loop(){
//reconnect if connection is lost
if (!client.connected() && WiFi.status() == 3) {reconnect();}
//maintain MQTT connection
client.loop();
//MUST delay to allow ESP8266 WIFI functions to run
delay(10);
void callback(char* topic, byte* payload, unsigned int length) {
//convert topic to string to make it easier to work with
String topicStr = topic;
//Print out some debugging info
Serial.println("Callback update.");
Serial.print("Topic: ");
Serial.println(topicStr);
//turn the light on if the payload is '1' and publish to the MQTT server a confirmation message
if(payload[0] == '1'){
digitalWrite(lightPin, HIGH);
//client.publish("/test/confirm", "Light On");
//turn the light off if the payload is '0' and publish to the MQTT server a confirmation message
else if (payload[0] == '0'){
//client.publish("/test/confirm", "Light Off");
void reconnect() {
//attempt to connect to the wifi if connection is lost
if(WiFi.status() != WL_CONNECTED){
//debug printing
Serial.print("Connecting to ");
Serial.println(ssid);
//loop while we wait for connection
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
//print out some more debug once connected
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
//make sure we are connected to WIFI before attemping to reconnect to MQTT
if(WiFi.status() == WL_CONNECTED){
// Loop until we're reconnected to the MQTT server
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Generate client name based on MAC address and last 8 bits of microsecond counter
String clientName;
clientName += "esp8266-";
uint8_t mac[6];
WiFi.macAddress(mac);
clientName += macToStr(mac);
//if connected, subscribe to the topic(s) we want to be notified about
if (client.connect((char*) clientName.c_str())) {
Serial.print("\tMTQQ Connected");
client.subscribe(lightTopic);
//otherwise print failed for debugging
else{Serial.println("\tFailed."); abort();}
//generate unique name from MAC addr
String macToStr(const uint8_t* mac){
String result;
for (int i = 0; i < 6; ++i) {
result += String(mac[i], 16);
if (i < 5){
result += ':';
return result;
Can anybody help me?
