Hello friends, I’ve been playing OH2 for 3 months and it’s so fascinating!
My system consists of a raspberry pi 3 and bunch of NODEMCUs around my house,which rasberry pi 3 is OH2 broker and NODEMCUs are so-called “slaves” (or “nodes” whatsoever) and are connected to raspberry via my home WIFI network.
The only problem I’m facing is that whenever I reboot my raspberry or my router, which causes rasp’s IP address to change, those NODEMCUs lose connection because in the arduino code, I only gave a static fixed Rasp’s IP address for NODEMCUs to connect to, This is quite a nuisance because I have to re-upload the code whenever I reset raspberry or my home network.
Is there anyway to overcome this?
Please help! Thanks in advance!
It said it would be a problems to have many DHCP servers in the network. Unfortunately, I am having 3 raspberry pi 3 at the moment and I need to change all of them into DHCP servers.
Don’t do that. In a normal home network, your router is the only DHCP server. Everything else should be a DHCP client.
The advice is to set up your router’s DHCP to issue the same IP to your Pi.
