I used VoiceRSS service to create a TTS system with OH version 1.8.3 on my raspberry pi 3. Here are my configuration under openhab.cfg:
###################### GoogleTTS configuration ############################
# The language to be used by the GoogleTTS engine (optional, default: 'en').
# Language must be supported for audio output by https://translate.google.com.
googletts:language=en-gb
# Sentence delimiters used to split text into sentences (optional, default: !.?:;)
# googletts:sentenceDelimiters=
# Google Translate URL to be used for converting text to speech (optional,
# defaults to http://translate.google.com/translate_tts?tl=%s&q=%s&client=t).
googletts:translateUrl=https://api.voicerss.org/?key=xxxx&hl=%s&src=%s
Where xxxx is my API key. In the rules file of mine:
rule "Dog Enable"
Item itm_dog_gps_alm_enb changed from OFF to ON
say("Hello")
I did have an switch item call “itm_dog_gps_alm_enb” before, but whenever I toggled the switch I didn’t hear any sound played by my raspberry pi. I did change the audio output of my rasp to 3.5mm jack and played a sample wav file, everything was OK, so I suppose there are several mistakes during my configuration. Anybody can help me, please? Thanks in advance
