Platform information:
- Hardware: MacBook, Raspberry Pi 4
- OS: macOS 11, Raspbian 10.7
- Java Runtime Environment: OpenJDK 8
- openHAB version: 2.5.10
Issue of the topic: triggeredItem and other variables are always ‘null’
Please post configurations (if applicable):
items
Group CAN
Group node1 (CAN)
Group node2 (CAN)
Number CAN_N2_Analog1 “N2.A1 [%.1f l/h]” (node2) {channel=“mqtt:topic:hassio:home_bus_can_node2:a1”}
Number CAN_N2_Analog2 “N2.A2 [%.1f W]” (node2) {channel=“mqtt:topic:hassio:home_bus_can_node2:a2”}
Number CAN_N2_Analog3 “N2.A3 [%.1f W]” (node2) {channel=“mqtt:topic:hassio:home_bus_can_node2:a3”}
Number CAN_N2_Analog4 “N2.A4 [%.1f W]” (node2) {channel=“mqtt:topic:hassio:home_bus_can_node2:a4”}
rules
rule “Node2Changed”
Member of node2 changed
logInfo(“calc”, “Something happened”)
logInfo(“calc”, triggeringItem)
end -
log:tail says
22:30:59.332 [INFO ] [smarthome.event.ItemStateChangedEvent] - CAN_N2_Analog1 changed from 1343 to 1340
22:30:59.333 [INFO ] [g.eclipse.smarthome.model.script.calc] - Something happened
22:30:59.335 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule ‘Node2Changed’: An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
What am I doing wrong?
I’ve invested ~30 hours in googling, trying with combinations of changed, received command, channel trigger… with the variables described at: https://www.openhab.org/docs/configuration/rules-dsl.html#implicit-variables-inside-the-execution-block
So, I have no idea…
I just want to know what is the item that triggered the rule, AKA the item that changed its state.
Thanks in advanced
Gerrit
