I am using the debian online package as described in the wiki. After an update today (with apt-get upgrade) when starting openhab2 it only says Please stand by while UIs are being installed. This can take several minutes. for as long as I let it run.
I tried rebooting, restarting the service, and now I am out of ideas.
Try to delete the file /var/lib/openhab2/config/org/openhab/addons.config and see if it works afterwards.
If the installation fails once (because your Internet connection might have been down), it does not automatically retry it currently.
Set the org.openhab to DEBUG, root to INFO, but no logging at all after startup and when initially open the GUI. Renamed all .config files in /var/lib/openhab2/config/ to .config.old. Restarted: no difference.
2017-01-19 19:16:31.651 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-01-19 19:16:33.675 [WARN ] [url.mvn.internal.AetherBasedResolver] - Error resolving artifact org.openhab.persistence:org.openhab.persistence.rrd4j:jar:1.9.0.RC1: [Could not find artifact org.openhab.persistence:org.openhab.persistence.rrd4j:jar:1.9.0.RC1]
java.io.IOException: Error resolving artifact org.openhab.persistence:org.openhab.persistence.rrd4j:jar:1.9.0.RC1: [Could not find artifact org.openhab.persistence:org.openhab.persistence.rrd4j:jar:1.9.0.RC1]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:720)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:659)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:600)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:567)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:36)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60)[8:org.apache.karaf.features.core:4.0.8]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_112]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_112]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_112]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_112]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_112]
Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.openhab.persistence:org.openhab.persistence.rrd4j:jar:1.9.0.RC1
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:444)
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246)
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:223)
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:294)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:705)[7:org.ops4j.pax.url.mvn:2.5.2]
... 12 more
2017-01-19 19:16:33.710 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-http1, openhab-persistence-mapdb, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-binding-sonos, openhab-binding-weather1, openhab-ui-habpanel, openhab-transformation-regex, openhab-ui-paper': Error
Hello bbrendon,
did you solve the problem?
I have the same and would be interested in a solution.
I tried to delete the addons.config. Then clicked again standard ⊠The same
Or can someone else help?
I dont know whats wrong but i cleared the cache âuserdata/cacheâ and after that everything is fine. Seems that something hangs in my system about once in a month allways ending to the same. After openhab2 restart allways Pleas standby while⊠and i have to reinstall all bindings and then its okay. not good for production.
same time my percistence data is not loggin it self. missing last days data and data is not going in but after cache clear everything is OK.
After waiting for 20 minutes, I clicked on âReload this pageâ in Chrome and the âWelcome to openHab2â screen with the HABPANEL, BASIC UI AND PAPER UI appeared. It turned out I had to specify âNo Proxyâ in Firefox.
mark@mega-server:/usr/share/openhab2$ ls -lh /var/log/openhab2/openhab.log
-rw-râr-- 1 root root 9.6M Nov 30 01:04 /var/log/openhab2/openhab.log
The file grew very large very quickly. It was complaining about a some item or sitemap configurations i had for snmp (old binding).
2017-11-30 01:01:32.873 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item '3plug12' to handler for channel 'network:device:ebc7d3e0:online', because no thing with the UID 'network:device:ebc7d3e0' could be found.
2017-11-30 01:01:35.388 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item '3plug12' to handler for channel 'network:device:ebc7d3e0:online', because no thing with the UID 'network:device:ebc7d3e0' could be found.
2017-11-30 01:01:36.315 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item '3plug12' to handler for channel 'network:device:ebc7d3e0:online', because no thing with the UID 'network:device:ebc7d3e0' could be found.
2017-11-30 01:01:37.316 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item '3plug12' to handler for channel 'network:device:ebc7d3e0:online', because no thing with the UID 'network:device:ebc7d3e0' could be found.
2017-11-30 01:01:38.317 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item '3plug12' to handler for channel 'network:device:ebc7d3e0:online', because no thing with the UID 'network:device:ebc7d3e0' could be found.
2017-11-30 01:01:39.340 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item '3plug12' to handler for channel 'network:device:ebc7d3e0:online', because no thing with the UID 'network:device:ebc7d3e0' could be found.
