I have developed an Amazon Dash button bindung for OH2 (GitHub). In order to improve the discovery process I would like to know the vendor prefix of your Amazon Dash Button’s MAC address.
I just need the frst three segments of the MAC address. So if the MAC address is FC:FB:FB:01:FA:21, you just have to post FC:FB:FB.
Additionally it would be helpful to get to know where (Country) and when you bought your Amazon Dash Button.
So, I start with my device:
ac:63:be, Germany, 05 Sept 2016
74:c2:46 and 74:75:48, about a year after they first came out in the U.S.
If you submit this to be included in the distro as an officail binding, make sure you make it very clear in the docs that this will require reconfiguring openHAB to run as root.
Also, typically the native libraries that are required come packaged with the binding and do not require the user to install something separately.
As mentioned there you do not have to run openHAB as root if you grant CAP_NET_RAW and CAP_NET_ADMIN to the java command which executes openHAB.
I don’t think that is reasonable as it depends on the os you use. I think it’s absolutely valid to define the installation of the native library as a prerequisite.
My Dashbutton starts with AC:63:BE (Germany).
Could you provide the addon for download or send it to me by mail? I don’t know how to compile it by myself…
Now it seems, that the Z-Wave-Binding doesn’t call the zwave-device-database anymore.
Before the commands it worked?!?
2016-10-01 15:54:14.492 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet, use default value: null
2016-10-01 15:54:14.493 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet6, use default value: null
2016-10-01 15:54:14.494 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.packet, use default value: null
2016-10-01 15:54:14.494 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
2016-10-01 15:54:15.998 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
2016-10-01 15:56:07.935 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:70d54c3f:node2' to inbox.
2016-10-01 15:56:20.896 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
What is the setcap? Can I revert to the state before for testing?
2016-11-02 16:25:51.007 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
2016-11-02 16:25:51.211 [ERROR] [nal.pcap.PcapNetworkInterfaceService] - An exception occurred while calling onPcapNetworkInterfaceAdded for org.openhab.binding.amazondashbutton.internal.discovery.AmazonDashButtonDiscoveryService@64c162
java.lang.RuntimeException: org.pcap4j.core.PcapNativeException: lo: You don't have permission to capture on that device (socket: Die Operation ist nicht erlaubt)
Any ideas?
Edit: output from sample application:
8 Devices found:
eth0 (192.168.2.237, fd00:0:0:0:ec03:f2b7:c580:32e2, fe80:0:0:0:cc13:7303:fe0b:5efd)
any (Pseudo-device that captures on all interfaces)
lo (127.0.0.1, 0:0:0:0:0:0:0:1)
wlan0 (fe80:0:0:0:991a:d12c:ffca:b278)
bluetooth0 (Bluetooth adapter number 0)
nflog (Linux netfilter log (NFLOG) interface)
nfqueue (Linux netfilter queue (NFQUEUE) interface)
usbmon1 (USB bus number 1)
Part of it (but now the dash button shows up in the inbox!):
2016-11-02 19:38:37.631 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
2016-11-02 19:38:56.915 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'amazondashbutton:dashbutton:ac-63-be-62-be-f5' to inbox.
