i used the Plex binding for month but some weeks ago it stop working. Because lag of time i tried now to get it working again but with no chance. I use openhab 1.8.3 and Plex binding in same version. I set up the server info in cfg file and different clients in items and sitemap like i had before. But no matter what client i try (PMP on Raspberry, Xbox, iPad, iphone) i do not get info like status, title or endgame like i got month before. Server is set to Prefer secure connections only.
I have no idea what i could still try now, maybe someone here has an idea or maybe a solution.
It’s going to quite difficult to assist you further without further information from your setup. To start with could you provide your config files. Remember to remove anything that could identify your account.
Here you finde the openhab.cfg of Plex, the items and sitemap code i use synth month.
Binding is 1.8.3 and openhab is 1.8.3, Plex media server and clients are the latest Plex pass version. Clients Raspberry Pi with PMP, iPad, iphone and xbox one.
############################### Plex Binding ##########################################
# IP address of the Plex server
plex:host=192.168.1.3
I’ve had similar problem with Plex binding. Adding OH IP address to the “List of IP addresses and networks that are allowed without auth” (even though my Plex and OH server are located on the same computer) solved the problem. I guess the problem was Plex Media Server update, which introduced that security setting. You can find this option in the Web UI of the Plex Media Server:
Go to settings
Choose Server
Click Show advanced button
Choose Network in the side menu
The option should be located near the bottom
Just add your OH IP address there, and it should work.
Have you checked to make sure you haven’t changed token by looking at the device list. https://plex.tv/devices.xml if memory serves me right. I’ve noticed this in the past where I’ve had to reboot my Plex server.
