just deleted that and rebooted openhabian with no change.
here is my items and sitemap files. maybe ive missed something simple?
Switch PlexTVPower "Power" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#power"}
String PlexTVStatus "Status [%s]" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#state"}
String PlexTVTitle "Title [%s]" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#title"}
String PlexTVType "Type [%s]" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#type"}
String PlexTVCover "Cover" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/cover"}
Dimmer PlexTVProgress "Progress [%.1f%%]" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/progress"}
DateTime PlexTVEndTime "End time [%1$tR]" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/endTime"}
Dimmer PlexTVVolume "Volume" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/volume"}
Switch PlexTVPause "Pause" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/pause"}
Switch PlexTVPlay "Play" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/play"}
Switch PlexTVPlayPause "PlayPause" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/playpause"}
Switch PlexTVStop "Stop" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/stop"}
Switch PlexTVSelect "Select" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#navigation/select"}
Switch PlexTVBack "Back" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#navigation/back"}
Switch PlexTVUp "Up" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#navigation/moveUp"}
Switch PlexTVDown "Down" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#navigation/moveDown"}
Switch PlexTVLeft "Left" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#navigation/moveLeft"}
Switch PlexTVRight "Right" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#navigation/moveRight"}
Switch PlexTVForward "Forward" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/stepForward"}
Switch PlexTVReverse "Reverse" <video> {plex="00E21940-D840-4B0F-AB72-A6924D0512ED#playback/stepBack"}
sitemap plexdemo label="Main Menu"
Frame {
Switch item=PlexTVPower
Text item=PlexTVStatus
Slider item=PlexTVProgress visibility=[PlexTVStatus!="Stopped"]
Setpoint item=PlexTVProgress visibility=[PlexTVStatus!="Stopped"] minValue=0 maxValue=100 step=1
Text item=PlexTVEndTime visibility=[PlexTVStatus!="Stopped"]
Text item=PlexTVTitle visibility=[PlexTVStatus!="Stopped"]
Text item=PlexTVType visibility=[PlexTVStatus!="Stopped"]
Switch item=PlexTVPause
Switch item=PlexTVPlay
Switch item=PlexTVPlayPause mappings=[ON="▐ ▌"]
Switch item=PlexTVStop mappings=[ON="Stop"]
Slider item=PlexTVVolume
Switch item=PlexTVSelect mappings=[ON="Select"]
Switch item=PlexTVBack mappings=[ON="Back"]
Switch item=PlexTVUp mappings=[ON="⬆"]
Switch item=PlexTVDown mappings=[ON="⬇"]
Switch item=PlexTVLeft mappings=[ON="⬅"]
Switch item=PlexTVRight mappings=[ON="➡"]
Switch item=PlexTVForward mappings=[ON="⤏"]
Switch item=PlexTVReverse mappings=[ON="⤎"]
# IP address or hostname of the Plex server
#host=
# Optional, port that the Plex server is running on. Default = 32400
#port=
# Refresh interval in ms. Default = 5000.
#refresh=5000
# If you're using Plex Home you need to supply the username and password of your
# Plex account here. If you don't want to enter your credentials you can also
# directly set your account token below instead.
#username=
# Plex password
#password=
# Plex account token, use instead of username/password when using Plex Home.
#token=abcdefghijklmnopqrst
host=192.168.178.60
port=32400
username=****@gmail.com
password=****
heres the log
item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=***, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
at org.openhab.binding.plex.internal.PlexConnector.getHost(PlexConnector.java:417) [212:org.openhab.binding.plex:1.11.0]
at org.openhab.binding.plex.internal.PlexConnector.sendCommand(PlexConnector.java:238) [212:org.openhab.binding.plex:1.11.0]
at org.openhab.binding.plex.internal.PlexBinding.internalReceiveCommand(PlexBinding.java:147) [212:org.openhab.binding.plex:1.11.0]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:94) [215:org.openhab.core.compat1x:2.2.0]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:45) [215:org.openhab.core.compat1x:2.2.0]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415) [3:org.apache.karaf.services.eventadmin:4.1.3]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.runWithoutBlacklistTiming(HandlerTask.java:82) [3:org.apache.karaf.services.eventadmin:4.1.3]
at org.apache.felix.eventadmin.impl.tasks.SyncDeliverTasks.execute(SyncDeliverTasks.java:104) [3:org.apache.karaf.services.eventadmin:4.1.3]
at org.apache.felix.eventadmin.impl.tasks.AsyncDeliverTasks$TaskExecuter.run(AsyncDeliverTasks.java:166) [3:org.apache.karaf.services.eventadmin:4.1.3]
2018-04-29 16:23:09.286 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=***, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:23:09.398 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password= ****, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:23:09.401 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=****, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:23:09.438 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVStop] {bridgemarker=true, item=PlexTVStop, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=***, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:23:09.442 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=****, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:23:09.480 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=****, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:23:09.484 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, username=****@gmail.com, refresh=5000, service.pid=org.openhab.plex, component.id=197, password=****, event.topics=openhab/command/*, host=192.168.178.60, service.id=338, service.bundleid=212, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.11.0 [212])]
2018-04-29 16:24:39.400 [INFO ] [work.internal.dhcp.DHCPListenService] - DHCP request for unknown address: 192.168.178.67
2018-04-29 16:25:01.838 [INFO ] [mmandclass.ZWaveDoorLockCommandClass] - NODE 31: Door-Lock config report - timeoutEnabled=false timeoutMinutes=254, timeoutSeconds=30
