While waiting for a review to get the initial binding for plugwise home automation merged, i’m thinking of adding some functionality in a follow up PR. While doing so i like to ask the more experienced to point me in the right direction.
This binding supports a range of devices including some valves that can be automatically-calibrated by performing a call to an API-endpoint.
If i translate this to openHAB, i think of a state channel and a linked item (switch) that can be turned ON and goes off immediate. When handling the command, i call the endpoint.
If i look at the documentation i see there is also a different channel type: trigger channel. I can hardly find any documentation for this. But if i look at the first picture in (Bindings | openHAB) the trigger channel has a label about firmware upgrade, and that is somewhat similar. Where can i find more documentation, or is there someone who can let me know what the best channel type or approach would be?
Thanks in advance
