while i´m upgrading from OH2 to OH3 i realised a little issue. I´m @ OH3.1.0 Release Build.
ModelTab
Locatin Tab
the two pictures show the same item “Fenster Sensor Stube->Status” at same time with different states. The Location Tab(picture 2) is not in sync. Thats just one sample.
Same problem, if i toggle a plug on/off in LocationTab, the plug do´nt react. In ModelTab no problem
Model and Items are created in .items File
Group location_Outdoor "Sternstrasse" <garden> ["Location"]
Group location_Wohnung "Wohnung" <house> (location_Outdoor) ["Location"]
Group location_Stube "Stube" <groundfloor> (location_Wohnung) ["Location"]
Group location_Bad "Bad" <groundfloor> (location_Wohnung) ["Location"]
Group location_Kueche "Kueche" <groundfloor> (location_Wohnung) ["Location"]
Group location_Flur "Flur" <groundfloor> (location_Wohnung) ["Location"]
Group location_VorFlur "vorFlur" <groundfloor> (location_Wohnung) ["Location"]
Group equip_zwaveFensterSensorBad "Fenster Sensor Bad" <window> (location_Bad) [Equipment]
Contact Fenster_Sensor_Bad_Status "Status" <switch> (equip_zwaveFensterSensorBad)[Point] {channel="zwave:kaipule_im20_00_000:kontakt01:sensor_door"}
Number Fenster_Sensor_Bad_Batterie "Batterieladung [%d %%]" <batterylevel> (equip_zwaveFensterSensorBad)[Point] {channel="zwave:kaipule_im20_00_000:kontakt01:battery-level"}
Group equip_zwaveFensterSensorKueche "Fenster Sensor Kueche" <window> (location_Kueche) [Equipment]
Contact Fenster_Sensor_Kueche_Status "Status" <switch> (equip_zwaveFensterSensorKueche)[Point] {channel="zwave:kaipule_im20_00_000:kontakt02:sensor_door"}
Number Fenster_Sensor_Kueche_Batterie "Batterieladung [%d %%]" <batterylevel> (equip_zwaveFensterSensorKueche)[Point] {channel="zwave:kaipule_im20_00_000:kontakt02:battery-level"}
Group equip_zwaveFensterSensorStube "Fenster Sensor Stube" <window> (location_Stube) [Equipment]
Contact Fenster_Sensor_Stube_Status "Status" <switch> (equip_zwaveFensterSensorStube)[Point] {channel="zwave:kaipule_im20_00_000:kontakt03:sensor_door"}
Number Fenster_Sensor_Stube_Batterie "Batterieladung [%d %%]" <batterylevel> (equip_zwaveFensterSensorStube)[Point] {channel="zwave:kaipule_im20_00_000:kontakt03:battery-level"}
Group equip_zwaveFensterSensorTuer "Tuer Sensor vorFlur" <door> (location_VorFlur) [Equipment]
Contact Fenster_Sensor_Tuer_Status "Status" <switch> (equip_zwaveFensterSensorTuer)[Point] {channel="zwave:kaipule_im20_00_000:kontakt04:sensor_door"}
Number Fenster_Sensor_Tuer_Batterie "Batterieladung [%d %%]" <batterylevel> (equip_zwaveFensterSensorTuer)[Point] {channel="zwave:kaipule_im20_00_000:kontakt04:battery-level"}
some advice? maybe a known issue - did´nt found in Forum?
so far i like OH3
