I have a number of sensors that send data to the serial port, some every second and some 10 times a second.
Right now I have my ports defined like:
String Outside_Air_Sensor {serial="/dev/ttyPort0@9600,BASE64"}
And rules that kick off when sensor receives update such as:
rule "Outside_Air_Sensor"
Item Outside_Air_Sensor received update
val to64 = DatatypeConverter::parseBase64Binary(Outside_Air_Sensor.state.toString)
val ByteBuffer bb = ByteBuffer::wrap(to64)
val short start = bb.getShort
val short length = bb.getShort
if (start==16973 && length==28) {
val short pm1 = bb.getShort
if (pm1>0) {
postUpdate(Outside_PM1, pm1.toString)
val short pm25 = bb.getShort
if (pm25>0) {
postUpdate(Outside_PM25, pm25.toString)
val short pm10 = bb.getShort
if (pm10>0) {
postUpdate(Outside_PM10, pm10.toString)
Things basically work, but I don’t need to know the air quality every second, or the level of my septic tank 10 times a second. Is there a way to write a rule that opens the serial port, based on cron say every 30 seconds, reads one value from the serial port and then closes it?
