i’m using the POPPs for two years and up to now they were working. But now they don’t report the alarm to the item that is assigned to the “alarm_general” channel. The binary sensor is still triggered. I didn’t change anything and my configuration for the parameters 1 to 4 is still on default. In the XML i found tor the command class that the alarm type is smoke:
<commandClass>ALARM</commandClass>
<alarmCommandClass>
<version>5</version>
<instances>1</instances>
<versionSupported>5</versionSupported>
<alarms>
<entry>
<alarmType>SMOKE</alarmType>
<alarmState>
<reportedEvents>
<int>2</int>
</reportedEvents>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
<isGetSupported>true</isGetSupported>
</alarmCommandClass>
But to my understanding alarm general should cover this.
Is there anybody with the same issue?
Christian
