I’m just trying to include the Popp Wall Plug Switch. The inclusion works and I can switch it ON/OFF. But I don’t see any values for power consumption and load and I can’t change the configuration of the thing.
The database for this device doesn’t contain any configuration parameters, and also doesn’t have any channels for meter command class. IF this is incorrect, then it would be good if you can add the configuration parameters at least.
I don’t know - I only went on your description of the “wall plug” and 5437 (as per the title of your message) which came up with the device I referenced. The one you now say is 05438?
As requested, can you please supply the XML that is generated from OH so we can be sure what device you actually have.
From the XML, it looks like everything should be ok. When you say there are no meter readings, do you mean there’s no channel for this, or that there’s a channel, but no data?
I don’t really see any problems from the XML - the configuration is in there, and the association to the lifeline group is set ok (Assuming your controller is node 1).
I’m not sure why you would have the error about not being able to find the configuration class - it’s clearly there.
Some of these zwave.me/Merten devices the last number is the colour or something minor that differentiates the model, so maybe it’s as simple as that…
Hi the channels have been there all the time but no values are transmitted. It always said NULL. Now the values for watts an kWh changed to 0.0. It seems that some magic happened but still no “real” values.
=> Yes, it is.
I just compared my manual with the database entries and I have found some difference.
Command Class Meter has Version 4 in the manual and 3 in the database.
Command Class Association has Version 2 in the manual and 1 in the database.
Could that be my problem? Any idea what I can do because my ideas ran out of stock
Very unlikely - the version number in the database is just information - it isn’t used as the binding will do its own thing. In any case the binding probably uses some older versions than the device, but they are backward compatible.
It’s time for a debug log . View it with the viewer on my website and see what it shows…
I just want to add that a restart of OH2 solved the issue. Today I just wanted to test again and it worked. I tried some restarts and so on yesterday which doesn’t have any effect.
