Popup for Shutter-Widget
Hi Community,
I built the following shutter widget with 5 information fields myself. Now I would like to change this to save space so that the last 4 pieces of information can only be seen via a POPUP. If possible, this window should be opened via a button.
Unfortunately, I am currently reaching my limits with this. Can someone help me?
Thanks in advance.
Here is the previous code:
uid: shutter_widget_v5
tags: []
props:
  parameters:
    - description: Title of the card (blank for none)
      label: Title
      required: false
      type: TEXT
    - description: The card footer (no footer!!)
      label: Footer
      required: false
      type: TEXT
    - description: Description Info 1 (<u>Suggestion:</u> <b>Interne Temperatur</b>)
      label: Info1
      required: true
      type: TEXT
    - description: Description Info 2 (<u>Suggestion:</u> <b>Total kWh</b>)
      label: Info2
      required: true
      type: TEXT
    - description: Description Info 3 (<u>Suggestion:</u> <b>Signal strength</b>)
      label: Info3
      required: true
      type: TEXT
    - description: Description Info 4 (<u>Suggestion:</u> <b>Firmware</b>)
      label: Info4
      required: true
      type: TEXT
    - description: Description Info 5 (<u>Suggestion:</u> <b>Shutter-Position</b>)
      label: Info5
      required: true
      type: TEXT
    - context: item
      description: Item for info 1 (<u>Example:</u> <b>_Geratetemperatur</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      description: Item for info 2 (<u>Example:</u> <b>_Gesamtverbrauch</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      description: Item for info 3 (<u>Example:</u> <b>_Signalstarke</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      description: Item for info 4 (<u>Example:</u> <b>_Firmwareaktualisierungvorhanden</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      description: Item for info 5 (<u>Example:</u> <b>__Steuerung0offen100geschlossen</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      description: Item for Rollershutter Control (<u>Example:</u> <b>_Steuerung0offen100geschlossen</b>)
      label: Item
      required: true
      type: TEXT
    - description: Set background color (blank for none)
      required: false
      type: TEXT
    - description: Set text color (blank for none)
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
timestamp: May 9, 2021, 3:16:39 AM
component: f7-card
  style:
    width: 250px
    background: '=(props.background) ? props.background : ""'
    color: '=(props.color) ? props.color : ""'
    filter: brightness(95%)
  title: =props.title
slots:
  default:
    - component: f7-card-content
      slots:
        default:
          - component: f7-row
              class:
                - display-flex flex-direction-row
                - justify-content-space-evenly
                - align-items-center
              style:
                width: 250px
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                      - flex-direction-column
                      - justify-content-center
                    style:
                      height: calc(100% - 30px)
          - component: oh-rollershutter-card
              item: =props.control
              dirIconsStyle: chevron_{dir}_square_fill
              stopIconStyle: stop_circle_fill
              style:
                background-color: rgba(246, 158, 81, 0.2)
          - component: f7-col
            slots:
              default:
                - component: oh-list
                  config: {}
                  slots:
                    default:
                      - component: oh-label-item
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          title: =props.title1
                          item: =props.item1
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            margin-right: 0px
                            z-index: 1
                          title: =props.title2
                          item: =props.item2
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          title: =props.title3
                          item: =props.item3
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          title: =props.title4
                          item: =props.item4
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          title: =props.title5
                          item: =props.item5
How about a button that has an action calling e.g. another widget.
Someone tried something similar here.
I did something like this in my shutter widget:
I will try to make a solution for myself from the example of @DrRSatzteil.
I would, however, welcome any other suggestions.
I now have a result that I am not entirely satisfied with. Here the pictures:
screenshot_8
and here the code:
uid: shutter_widget_v7
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
    - description: Description Info 1 (<u>Suggestion:</u> <b>Firmware</b>)
      label: Info1
      required: true
      type: TEXT
      label: Info2
      required: true
      type: TEXT
      label: Info3
      required: true
      type: TEXT
    - description: Description Info 4 (<u>Suggestion:</u> <b>Interne Temperatur</b>)
      label: Info4
      required: true
      type: TEXT
      label: Info5
      required: true
      type: TEXT
    - context: item
      description: Item for info 1 (<u>Example:</u> <b>_Firmwareaktualisierungvorhanden</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      description: Item for info 4 (<u>Example:</u> <b>_Gerätetemperatur</b>)
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
      required: false
      type: TEXT
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
timestamp: Apr 29, 2022, 5:30:07 AM
component: f7-card
  style:
    width: 250px
  title: =props.title
slots:
  default:
      slots:
        default:
          - component: f7-row
              class:
              style:
                width: 250px
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                    style:
              style:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          item: =props.item1
                          style:
                            font-size: 13px
                            margin-bottom: 0px
                            margin-left: 0px
                            margin-top: 5px
                            width: 220px
                            z-index: 1
          - component: f7-row
              class:
                - display-flex
              style:
                height: 25px
            slots:
              default:
                - component: oh-link
                    action: popup
                    actionModal: widget:infos_popup_v7
                    actionModalConfig:
                      item2: =props.item2
                      item3: =props.item3
                      item4: =props.item4
                      item5: =props.item5
                      title: =props.title
                      title2: =props.title2
                      title3: =props.title3
                      title4: =props.title4
                      title5: =props.title5
                      title6: ='weitere Daten:'
                    actionPosition: center
                    text: ='mehr...'
uid: infos_popup_v7
tags: []
props:
  parameters: []
  parameterGroups: []
timestamp: Apr 29, 2022, 5:36:40 AM
component: f7-card
  style:
    width: 250px
    color: peru
  title: =props.title
slots:
  default:
      slots:
        default:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            margin-right: 0px
                            z-index: 1
                          item: =props.item2
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          item: =props.item3
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          item: =props.item4
                          style:
                            width: 220px
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          item: =props.item5
    - component: oh-button
        class:
          - margin-horizontal
        fill: true
        large: true
        popupClose: true
        round: true
        text: ='Close'
Unfortunately, I haven’t managed to reduce the Image popup widget to a specific size yet.
Does anyone of you have a tip for me?
Thanks in advance!
You may want to try a popover instead. It only has the size of your components unlike the relatively big popup component.
I already had this idea. However, I didn’t manage to implement it. How does the code have to be structured then?
Could you help me with this?
I might be wrong but as far as I remember all you need to do is change the popup action to a popover action.
I don’t know if this works with a f7-card component. Maybe you could drop the card and use a block component instead of the card-content. But I would also need to try this. Maybe someone else knows a definite answer?!
That may be, but I’m really overwhelmed with it. In the meantime, however, I have also made a little progress with a popover campaign. However, the output is always displayed at the top left of the screen. Maybe someone else can tell me how to place the “infos_popup_v7” widget in the middle of the screen.
Here are the pictures:
screenshot_11
screenshot_10
… and here the code:
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
      label: Info1
      required: true
      type: TEXT
      label: Info2
      required: true
      type: TEXT
      label: Info3
      required: true
      type: TEXT
      label: Info4
      required: true
      type: TEXT
      label: Info5
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
      required: false
      type: TEXT
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
timestamp: Apr 30, 2022, 3:15:15 PM
component: f7-card
  style:
    width: 250px
    height: 250px
  title: =props.title
slots:
  default:
      slots:
        default:
          - component: f7-row
              class:
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                    style:
              style:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          item: =props.item1
                          style:
                            font-size: 13px
                            margin-bottom: 0px
                            margin-left: 0px
                            margin-top: 5px
                            width: 220px
                            z-index: 1
          - component: f7-row
              class:
                - display-flex
              style:
                height: 25px
            slots:
              default:
                    title0: Something
                    outline: true
                    action: popover
                    actionModalConfig:
                      item2: =props.item2
                      item3: =props.item3
                      item4: =props.item4
                      item5: =props.item5
                      title: =props.title
                    fill: true
                    text: mehr ...
                    style:
                      position: absolute
                      top: 160px
                      left: 15px
                      text-align: center
                    popoverOpen: .popOver
                - component: f7-popover
                    class: popOver
                    closeByBackdropClick: true
                    closeByOutsideClick: true
                    backdrop: false
                    closeOnEscape: true
                    style:
                      vertical-align: center
                      horizontal-align: center
uid: infos_popup_v7
tags: []
props:
  parameters: []
  parameterGroups: []
timestamp: Apr 30, 2022, 5:00:35 AM
component: f7-card
  style:
    position: absolute
    color: peru
  title: =props.title
slots:
  default:
      slots:
        default:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          style:
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            margin-right: 0px
                            z-index: 1
                          item: =props.item2
                          style:
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          item: =props.item3
                          style:
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          item: =props.item4
                          style:
                            font-size: 13px
                            margin-left: 0px
                            margin-bottom: 0px
                            margin-top: 5px
                            z-index: 1
                          item: =props.item5
The position of the popover is determined by the popover’s parent, I believe. In the case where you use the built-in OH popover action, that parent is the window and therefore the popover is aligned with the window. To make the popover aligned with some part of your widget, the popover has to be built inside the widget.
This is not as bad as it sounds, and, in fact, you’re most of the way there already. While you’re using the OH popover action, all these lines:
                    class: popOver
                    backdrop: false
                    closeOnEscape: true
                    style:
are not doing anything. They do not reference the widget that you just happen to be opening as a popover. They are however, exactly what you want if you are incorporating your own popup into the widget. Just take all the components from your infos_popup and place them in the default slot of the f7-popup component.
Then you can just get rid of all the action based keys in the oh-button and just keep the popoverOpen key. You may want a more descriptive class name than just ‘popOver’ the element will already have that class. But if you use something like class: info-pop and just set the popoverOpen and popoverClose properties to .popover.info-pop you should be well on your way.
If you want to see an example you can just look at the code for my widget here (use the link at the bottom - the same widget also has built-in popups if you’re rather use that instead of a popover).
Many thanks for the answer. I understood part of your solution. However, I have to deal with her example first, which will take me some time.
Sorry, this is very difficult for me, are there any other examples I could look at?
No worries, building the popups/popovers in the widgets does get a little involved. The basics are as follows:
In your widget you need an f7-popup or f7-popover component as a child of the main widget component. In your case, that main component is the f7-card, so your basic structure is something like this:
component: f7-card
  ...card config
slots:
  default:
      ...all your basic visible components as you're already laid out
        ...popover configurations
      slots:
        default:
           ...all the components for your popover
The only other step is to make sure that you have at least one component on the widget that can open the popover and some way to close the popover once it’s open. For this you have to use the f7 built-in popoverOpen and popoverClose properties; you can’t use the oh specific actions. Using popoverOpen and popoverClose, is however pretty easy. Each of them just take a css identifier that points to the element you want opened/closed. For reasons specific to css in this case it is best just to stick to css classes (which are identified with a ‘.’ in front of them). First then, you have to assign a fairly unique class name to your popover. Every popup automatically gets a class of popup and every popover gets popover, but you don’t want it to be one of these generic names in case your widget gets more complicated because then there might be some confusion as to which element you are trying to open. So, best to just add your own additional class.
    class: some-unique-class-name
Second, once you have a unique class name, then you just use that for the popoverOpen and popoverClose values. If you want to be even more precise about what you are identifying, then you can included the generic class as well by chaining together the css class names.
- component: some-widget-component
    popoverOpen: .popover.some-unique-class-name
    ...rest of the component config
If you want the popover to automatically close when you’ve interacted with it, then you just use popoverClose on any of the components in the popover that your likely to click on or specifically add a close button.
      slots:
        default:
              popoverClose: .popover.some-unique-class-name
              text: Close popover
          ...rest of popover
I’m impressed how much effort they put into helping me. Thanks for that, but I can deal with that later.
I’ll get back…
I’m sorry, I’m throwing in the towel - I’m giving up. Many hours spent on this now and no result. Here is my last code, maybe someone will succeed and have more success than me:
uid: shutter_widget_v9
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
      label: Info1
      required: true
      type: TEXT
      label: Info2
      required: true
      type: TEXT
      label: Info3
      required: true
      type: TEXT
      label: Info4
      required: true
      type: TEXT
      label: Info5
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
      required: false
      type: TEXT
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
timestamp: May 1, 2022, 3:36:16 AM
component: f7-card
  style:
    width: 250px
    height: 250px
  title: =props.title
slots:
  default:
      slots:
        default:
          - component: f7-row
              class:
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                    style:
              style:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          item: =props.item1
                          style:
                            font-size: 13px
                            margin-bottom: 0px
                            margin-left: 0px
                            margin-top: 5px
                            width: 220px
                            z-index: 1
          - component: f7-row
              class:
                - display-flex
              style:
                height: 25px
            slots:
              default:
                    class: info-pop
                    backdrop: false
                    closeOnEscape: true
          - component: f7-row
              class:
                - display-flex
              style:
                height: 25px
            slots:
              default:
                  slots:
                    default:
                        slots:
                          default:
                            - component: f7-list-item
                              slots:
                                default:
                                      popoverOpen: .popover.info-pop
                                      popoverClose: .popover.info-pop
                                      outline: true
                                      action: popover
                                      fill: true
                                      text: mehr ...
@JustinG
Thank you once again for your support. It seems as if I’m reaching my limits here as a layman.
Sorry, you got very close. I see from what you put here where my previous post was a little confusing. If you wish to come back to this at some point, here’s what I would do with what you’ve posted. Really I’ve just changed the level of the popover and moved the button to the body of the widget so that it’s there to allow you to open the popover:
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
      label: Info1
      required: true
      type: TEXT
      label: Info2
      required: true
      type: TEXT
      label: Info3
      required: true
      type: TEXT
      label: Info4
      required: true
      type: TEXT
      label: Info5
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
      required: false
      type: TEXT
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
component: f7-card
  style:
    width: 250px
    height: 250px
  title: =props.title
slots:
  default:
      slots:
        default:
          - component: f7-row
              class:
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                    style:
              style:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          item: =props.item1
                          style:
                            font-size: 13px
                            margin-bottom: 0px
                            margin-left: 0px
                            margin-top: 5px
                            width: 220px
                            z-index: 1
                    outline: true
                    action: popover
                    fill: true
                    text: mehr ...
        class: info-pop
        backdrop: false
        closeOnEscape: true
      slots:
        default:
          - component: Label
              text: replace this label component with the heirarchy of components from your popup widget
@JustinG you are the greatest for me! Of course, I must continue with your submission. Take a look at what has become of it:
screenshot_2
However, I would like to make the popover a little larger so that it at least covers part of the base widget. I would also be interested in how the titles and items are displayed in a row in the popover. Can you give me any tips on this?
Here is the current code:
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
      label: Info1
      required: true
      type: TEXT
      label: Info2
      required: true
      type: TEXT
      label: Info3
      required: true
      type: TEXT
      label: Info4
      required: true
      type: TEXT
      label: Info5
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
      required: false
      type: TEXT
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
timestamp: May 2, 2022, 4:14:58 PM
component: f7-card
  style:
    width: 250px
    height: 230px
  title: =props.title
  left: center
slots:
  default:
      slots:
        default:
          - component: f7-row
              class:
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                    style:
              style:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          style:
                            font-size: 13px
                            margin-bottom: 0px
                            margin-left: 0px
                            margin-top: 5px
                            width: 220px
                            z-index: 1
                          item: =props.item1
                    outline: true
                    raised: true
                    action: popover
                    fill: true
                    text: mehr ...
                    style:
                      position: absolute
                      top: 150px
                      left: 90px
                      text-align: center
        class: info-pop
        backdrop: false
        closeOnEscape: true
      slots:
        default:
              style:
                font-size: 13px
                margin-left: 0px
                margin-bottom: 0px
                margin-top: 5px
                margin-right: 0px
                -index: 1
              item: =props.item2
              style:
                font-size: 13px
                margin-left: 0px
                margin-bottom: 0px
                margin-top: 5px
                margin-right: 0px
                -index: 1
              item: =props.item3
              style:
                font-size: 13px
                margin-left: 0px
                margin-bottom: 0px
                margin-top: 5px
                margin-right: 0px
                -index: 1
              item: =props.item4
              style:
                font-size: 13px
                margin-left: 0px
                margin-bottom: 0px
                margin-top: 5px
                margin-right: 0px
                -index: 1
              item: =props.item5
Note:
May I send you a personal message?
This is fairly easy. You can add style settings directly to the popover component. In this case the default width of the popover seems to be 200px so if you want to make it a little wider, you would do something like this:
        class: info-pop
        backdrop: false
        closeOnEscape: true
        style:
          width: 250px
You’re oh-label-items are not displaying the way you intend because they are not inside a list at the moment. All the components that end in -item are built to be the child components of a list; usually either a basic oh-list or a standalone oh-list-card. So in this case you want the fist component of your popover to be an oh-list and make all the label items children of that list, like this:
        class: info-pop
        backdrop: false
        closeOnEscape: true
        style:
          width: 250px
      slots:
        default:
              simpleList: true
            slots:
              default:
                    style:
                      font-size: 13px
                      margin-left: 0px
                      margin-bottom: 0px
                      margin-top: 5px
                      margin-right: 0px
                      -index: 1
                    item: =props.item2
...rest of the label items...
Of course.
I think everything is working very well now. Here is the result again:
screenshot_3
screenshot_4
and the code:
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
      label: Info1
      required: true
      type: TEXT
      label: Info2
      required: true
      type: TEXT
      label: Info3
      required: true
      type: TEXT
      label: Info4
      required: true
      type: TEXT
      label: Info5
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
    - context: item
      label: Item
      required: true
      type: TEXT
      required: false
      type: TEXT
      required: false
      type: TEXT
      advanced: false
  parameterGroups: []
timestamp: May 2, 2022, 5:54:09 PM
component: f7-card
  style:
    width: 250px
    height: 230px
  title: =props.title
  left: center
slots:
  default:
      slots:
        default:
          - component: f7-row
              class:
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                    style:
              style:
          - component: f7-col
            slots:
              default:
                  config: {}
                  slots:
                    default:
                          style:
                            font-size: 13px
                            margin-bottom: 0px
                            margin-left: 0px
                            margin-top: 5px
                            width: 220px
                            z-index: 1
                          item: =props.item1
                    outline: true
                    raised: true
                    action: popover
                    fill: true
                    text: mehr / weniger ...
                    style:
                      position: absolute
                      top: 150px
                      left: 55px
                      text-align: center
        class: info-pop
        backdrop: false
        closeOnEscape: true
        style:
          width: 250px
      slots:
        default:
              simpleList: true
            slots:
              default:
                    style:
                      font-size: 14px
                      margin-left: 0px
                      margin-bottom: 0px
                      margin-top: 5px
                      margin-right: 0px
                      -index: 1
                    item: =props.item2
                    style:
                      font-size: 14px
                      margin-left: 0px
                      margin-bottom: 0px
                      margin-top: 5px
                      margin-right: 0px
                      -index: 1
                    item: =props.item3
                    style:
                      font-size: 14px
                      margin-left: 0px
                      margin-bottom: 0px
                      margin-top: 5px
                      margin-right: 0px
                      -index: 1
                    item: =props.item4
                    style:
                      font-size: 14px
                      margin-left: 0px
                      margin-bottom: 0px
                      margin-top: 5px
                      margin-right: 0px
                      -index: 1
                    item: =props.item5
I still have one question: how do you set the color of the item values?
