Hey there,
is there anybody who could tell me, how I could implement a PopUp Widget? My first thougths are the following: I would create a template widget like this demo code:
<div class="row">
<div class="col-xs-4"><span><widget-icon iconset="'smarthome-set'" icon="'temperature'" /></span>Temperature</div>
<div class="col-xs-4"><span><widget-icon iconset="'smarthome-set'" icon="'drop'" /></span>Humidity</div>
<div class="col-xs-4"><span><widget-icon iconset="'smarthome-set'" icon="'thermostat'" /></span>Pressure</div>
</div>
<div class="row">
<div class="col-xs-4"><span style="color: red; font-size: 28pt">{{itemValue('Outside_Temperature')}}°C</span></div>
<div class="col-xs-4"><span style="color: cyan; font-size: 28pt">{{itemValue('Outside_Humidity')}}%</span></div>
<span style="color: green; font-size: 28pt">
{{'%.02f' | sprintf:itemValue('Outside_Pressure')/10000}}<small style="font-size:8pt">MPa</small>
</span>
</div>
</div>
<table class="table">
<tr>
<td class="text-right">Sunrise:</td>
<td><strong>{{itemValue('astro_sun_local_rise_start') | date:'HH:mm'}}</strong></td>
</tr>
<tr>
<td class="text-right">Sunset:</td>
<td><strong>{{itemValue('astro_sun_local_set_start') | date:'HH:mm'}}</strong></td>
</tr>
<tr>
<td class="text-right">Season:</td>
<td><strong>{{itemValue('astro_sun_local_season_name')}}</strong></td>
</tr>
</table>
when the widget is clicked on I would like to show a modal dialog where I could set the temperature .
How could it implement angularjs code within the html example?
Greetings Dominic
