This is basically the only reason I have not moved to OH2.
Oh and the crappy thing generation through the UI.
I really hope there will be a textual thing definition approach again.
The PR āscriptable automation #1783ā was merged in April. But I couldnāt find any documentation. Is it usable in OpenHab2 already? Iām eager to finally migrate to OH2.
First installation instructions for very early adapters:
Please use in nightly builds after 2017/05/30, because there was a problem with rules id definition before: https://github.com/eclipse/smarthome/pull/3534
Nice, thanks for the link. Somehow I didnāt find it.
Later a complete documentation will be found here: http://docs.openhab.org/configuration/rules-ng.html
@lewie thank you for the link on the JSR223 integration. Not being fully into the underbelly of OH2, would you please clarify the section āInstall in IDEā (especially the file path of the launch config) and section āJythonā (especially what Main page of launch config is and where to put the jython jar)?
Thank you very much in advance!
I was wondering - is there any plan when this makes its way to stable?
Iām using the openhab-2.2.0-snapshot docker image (from today, 9.7.17), but my example.js is not executed.
The misc-ruleengine shows as installed in PaperUI and my example.js (from the documentation) exists in conf/automation/jsr223, but it is not executed and I canāt find any log-entry concerning the jsr rule-engine in the logs.
Am I missing something?
Thanks,
Axel
@aruder77, when you get no log entries, misc-ruleengine seams not to be started.
At startup you MUST see this log entry [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
. It shows if misc-ruleengine is started and any *.js files are found.
For testing, do /etc/init.d/openhab stop
at bash, then search for start.sh
in openHAB folders and start openHAB with sh start.sh
. (Now, after openHAB Logo, your prompt goes blue, and looks like openhab>
Then you can do a openhab>list
at openHAB console there you should see a block like:
ā¦
185 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation API
186 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation commands
187 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Core
188 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Module Core
189 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Media Modules
190 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Module Script
191 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Script Globals
192 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Script RuleSupport
193 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Module Timer
194 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation GSON Parser
195 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation Providers
196 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Automation REST API
ā¦
If yes, go to live log with openhab>log:tail
(later left live console with ctrl-c). Open example.js
in your editor and change anything (add a blank or so) and save back in conf/automation/jsr223
. At that moment, when example.js
is saved. In live console you should see entries like:
ā¦
09:06:57.369 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script āexample.jsā
09:06:57.408 [INFO ] [smarthome.event.RuleAddedEvent ] - Rule ārule_1ā has been added.
09:06:57.409 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: INITIALIZING
09:06:57.412 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: IDLE
09:07:00.006 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: RUNNING
09:07:00.014 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: IDLE
Hello World from JavaScript
09:07:15.016 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: RUNNING
09:07:15.016 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: IDLE
09:07:30.013 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: RUNNING
09:07:30.013 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - rule_1 updated: IDLE
ā¦
I hope this can help.
Thanks a lot for your quick and detailed answer!
With your help I could track down the problem. I was actually mounting the automation scripts in the wrong location, so that they were not picked up. The example.js is now loaded, but there still seems to be a minor problem:
Error during evaluation of script āfile:/openhab/conf/automation/jsr223/example.jsā: ReferenceError: āSimpleRuleā is not defined in at line number 6
I will try a groovy/jython script and see how it goes.
Thanks again!
Can you provide some documentation what you have been doing so I can follow up?
This would be very helpful.
@Spaceman_Spiff and @aruder77, it is still an early rather experimental stage. Here we are currently collecting information for the later documentation. As a very early adapter there you can find links to examples too.
I hope you have so much fun as me!
PS: You are of course welcome to help us improve the documentation!
I have an open PR with openhab-docs to document the language-independent aspects of the JSR223 support with additional documentation specific to Jython. Iām not getting much feedback so any participation there is welcome and may speed up the process of publishing the material. After the PR is merged it will provide a place to add further details for Javascript and Groovy.
@lewie, @Spaceman_Spiff and @aruder77 and others. The OH2 JSR223 documentation is now available at:
http://docs.openhab.org/configuration/jsr223.html
Thanks to @ThomDietrich and @Benjy for the PR reviews.
Thanks a lot @steve1 and @lewie for the help and the documentation!
Unfortunately I still canāt get it to work up to now. I tried JS, jython and groovy, but apparently my presents arenāt loaded correctly.
With the examples from the documentation, I get the following log entries:
2017-07-16 18:14:39.031 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for Groovy
2017-07-16 18:14:40.390 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
2017-07-16 18:14:40.397 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for python
2017-07-16 18:15:05.614 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'example.groovyā
2017-07-16 18:15:09.623 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script āfile:/openhab/conf/automation/jsr223/example.groovyā: javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: automationManager for cl
ass: Script1
2017-07-16 18:15:09.637 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'example.pyā
2017-07-16 18:15:41.494 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script āfile:/openhab/conf/automation/jsr223/example.pyā: NameError: name āSimpleRuleā is not defined in at line number 5
2017-07-16 18:15:41.504 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'exampleJs.jsā
2017-07-16 18:15:46.060 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script āfile:/openhab/conf/automation/jsr223/exampleJs.jsā: ReferenceError: āSimpleRuleā is not defined in at line number 6
Iām using @lewieās snapshot version with ESH snapshotsā¦
Any hint?
Thanks!
Yesterday I installed the nightly build (#986) and started playing with the jsr223 script support. I ended up with doing nothing else than downloading the jython standalone jar and place it in runtime/lib/ext. After that Python scripts started to work. Unfortunately it doesnāt work after a restart of openHAB. The log looks like this:
2017-07-17 15:41:35.607 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for python
2017-07-17 15:41:35.624 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
2017-07-17 15:42:21.265 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/opt/openhab/openhab-2.x/conf/automation/jsr223/sample_trigger.py': NameError: name 'SimpleRule' is not defined in <script> at line number 5
If I touch the file sample_trigger.py everything starts to work:
2017-07-18 07:49:20.575 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'sample_trigger.py'
2017-07-18 07:50:17.723 [INFO ] [clipse.smarthome.automation.examples] - JSR223 [Jython]: Alarm watchdog was updated!
2017-07-18 07:51:17.691 [INFO ] [clipse.smarthome.automation.examples] - JSR223 [Jython]: Alarm watchdog was updated!
Any ideas?
BTW. This feature looks absolutely awsome, Just what I have been waiting for
Thanks!
By the way the script looks like this:
from org.slf4j import LoggerFactory
scriptExtension.importPreset("RuleSupport")
scriptExtension.importPreset("RuleSimple")
class myRule(SimpleRule):
def __init__(self):
self.triggers = [
Trigger("MyTrigger", "core.ItemStateUpdateTrigger",
Configuration({ "itemName": "Alarm_IsAlive"}))
def execute(self, module, input):
LoggerFactory.getLogger("org.eclipse.smarthome.automation.examples").info("JSR223 [Jython]: Alarm watchdog was updated!")
#events.postUpdate("TestString2", "some data")
sRule = myRule()
#sRule.setTriggers([Trigger("aTimerTrigger", "timer.GenericCronTrigger", Configuration({"cronExpression": "0/15 * * * * ?"}))])
automationManager.addRule(sRule)
I have also tried to put the jython jar in runtime/lib/boot instead, but that doesnāt make any difference at all.
I know very little of jython, only āsomeā python (I write my py procedural )ā¦so I have a couple of questions about this:
can I use external python libraries (3rd party) in these jython scripts? (like āimport blablaā) ?
How does scope work between scripts? if I create a āglobalā variable, would it āpersistā every time the script runs? is the scope shared between scripts, as in, would a globally defined variable be accessible between scripts?
Yes, you can either create your own Python modules that live outside of automation/jsr223
or use third-party libraries. Pure Python libraries will often work with Jython.
You can also use third-party Java libraries. For example, Iāve been experimenting with integration of the Esper CEP (Complex Event Processing) engine.
Typically, the JSR223 scope is not changed by a script. When a script is reloaded it is completed recreated so no variables that live in that script āmoduleā will survive. Also, script-level variables cannot be shared with other scripts. However, there are ways to share data between scripts and have the data survive script reloads. I do this by defining a module outside the automation\jsr223
directory (I use the Jython python.path
JVM argument to specify this external library directory location).
Only scripts in the automation\jsr223
directory are reloaded automatically. Python modules outside that directory are imported/loaded the normal Python way.
When those external module are imported there is only one instance of the module shared among the scripts. If you define variables in that module they can be shared and their lifespan is not affected by script reloading (other than the first import which loads the module). Note that if you are changing the implementation of an external module, youāll need to use reload(<module.name>)
to explicitly reload it since that will not happen automatically. Again, only scripts are reloaded automatically.
Although I said a script doesnāt typically change the JSR223 scope, it is possible to do it. You can use Jython to create a custom āpresetā, similar to āRuleSimpleā, that will inject additional objects into the JSR223 scope. Those objects will typically have a lifespan not affected by script reloads.
Thatās odd. It sounds like it is possibly a OSGI bundle load ordering issue or something like that. Iām using a development environment for testing and Iām also using a different technique to add the Jython library to the classpath and I donāt use the standalone JAR. So, lots of differences.
Maybe @smerschjo can comment, but one possibility is that the scripts are initially being loaded before the scope providers have run (which provides the āSimpleRuleā class to the scope). I am a bit short on time right now (packing for a move) but at some point Iāll install a snapshot build and try to reproduce your issue.
Also, which operating system are you using? Iām running on an RPi3 (Linux) and I configured Jython in the /etc/default/openhab2
file.
EXTRA_JAVA_OPTS=-Xbootclasspath/a:/home/pi/jython2.7.0/jython.jar \
-Dpython.home=/home/pi/jython2.7.0 \
-Dpython.path=/etc/openhab2/lib/python
