As you see, there is allready an open issue. If I understood right, the handler gives openhab the information about the ports causes this error, so it’s like a lottery if USB-Port is found or not.
Forgot to mention, it happens to my RS485 USB dongle as well. So this is not restricted to zwave dongles.
Could this be caused by changed symlinks to the tty devices?
What serial ports and symlinks do you see with ls -l /dev
[23:31:52] openhabian@openHABianPi:~$ ls -l /dev
total 0
crw-r--r-- 1 root root 10, 235 Apr 29 11:12 autofs
drwxr-xr-x 2 root root 580 Apr 29 11:12 block
drwxr-xr-x 2 root root 60 Jan 1 1970 bsg
crw------- 1 root root 10, 234 Apr 29 11:12 btrfs-control
drwxr-xr-x 3 root root 60 Jan 1 1970 bus
crw------- 1 root root 10, 63 Apr 29 11:12 cachefiles
drwxr-xr-x 2 root root 2580 Apr 29 11:12 char
crw------- 1 root root 5, 1 Apr 29 11:12 console
crw------- 1 root root 10, 62 Apr 29 11:12 cpu_dma_latency
crw------- 1 root root 10, 203 Apr 29 11:12 cuse
drwxr-xr-x 7 root root 140 Apr 29 11:12 disk
crw-rw---- 1 root video 29, 0 Apr 29 11:12 fb0
lrwxrwxrwx 1 root root 13 Nov 3 2016 fd -> /proc/self/fd
crw-rw-rw- 1 root root 1, 7 Apr 29 11:12 full
crw-rw-rw- 1 root root 10, 229 Apr 29 11:12 fuse
crw-rw---- 1 root gpio 254, 0 Apr 29 11:12 gpiochip0
crw-rw---- 1 root gpio 254, 1 Apr 29 11:12 gpiochip1
crw-rw---- 1 root gpio 248, 0 Apr 29 11:12 gpiomem
crw------- 1 root root 10, 183 Apr 29 11:12 hwrng
lrwxrwxrwx 1 root root 25 Nov 3 2016 initctl -> /run/systemd/initctl/ fifo
drwxr-xr-x 2 root root 60 Jan 1 1970 input
crw-r--r-- 1 root root 1, 11 Apr 29 11:12 kmsg
lrwxrwxrwx 1 root root 28 Nov 3 2016 log -> /run/systemd/journal/dev- log
brw-rw---- 1 root disk 7, 0 Apr 29 11:12 loop0
brw-rw---- 1 root disk 7, 1 Apr 29 11:12 loop1
brw-rw---- 1 root disk 7, 2 Apr 29 11:12 loop2
brw-rw---- 1 root disk 7, 3 Apr 29 11:12 loop3
brw-rw---- 1 root disk 7, 4 Apr 29 11:12 loop4
brw-rw---- 1 root disk 7, 5 Apr 29 11:12 loop5
brw-rw---- 1 root disk 7, 6 Apr 29 11:12 loop6
brw-rw---- 1 root disk 7, 7 Apr 29 11:12 loop7
crw-rw---- 1 root disk 10, 237 Apr 29 11:12 loop-control
drwxr-xr-x 2 root root 60 Apr 29 11:12 mapper
crw-r----- 1 root kmem 1, 1 Apr 29 11:12 mem
crw------- 1 root root 10, 59 Apr 29 11:12 memory_bandwidth
drwxrwxrwt 2 root root 40 Jan 1 1970 mqueue
drwxr-xr-x 2 root root 60 Apr 29 11:12 net
crw------- 1 root root 10, 61 Apr 29 11:12 network_latency
crw------- 1 root root 10, 60 Apr 29 11:12 network_throughput
crw-rw-rw- 1 root root 1, 3 Apr 29 11:12 null
crw------- 1 root root 108, 0 Apr 29 11:12 ppp
crw-rw-rw- 1 root tty 5, 2 May 2 23:31 ptmx
drwxr-xr-x 2 root root 0 Nov 3 2016 pts
brw-rw---- 1 root disk 1, 0 Apr 29 11:12 ram0
brw-rw---- 1 root disk 1, 1 Apr 29 11:12 ram1
brw-rw---- 1 root disk 1, 10 Apr 29 11:12 ram10
brw-rw---- 1 root disk 1, 11 Apr 29 11:12 ram11
brw-rw---- 1 root disk 1, 12 Apr 29 11:12 ram12
brw-rw---- 1 root disk 1, 13 Apr 29 11:12 ram13
brw-rw---- 1 root disk 1, 14 Apr 29 11:12 ram14
brw-rw---- 1 root disk 1, 15 Apr 29 11:12 ram15
brw-rw---- 1 root disk 1, 2 Apr 29 11:12 ram2
brw-rw---- 1 root disk 1, 3 Apr 29 11:12 ram3
brw-rw---- 1 root disk 1, 4 Apr 29 11:12 ram4
brw-rw---- 1 root disk 1, 5 Apr 29 11:12 ram5
brw-rw---- 1 root disk 1, 6 Apr 29 11:12 ram6
brw-rw---- 1 root disk 1, 7 Apr 29 11:12 ram7
brw-rw---- 1 root disk 1, 8 Apr 29 11:12 ram8
brw-rw---- 1 root disk 1, 9 Apr 29 11:12 ram9
crw-rw-rw- 1 root root 1, 8 Apr 29 11:12 random
drwxr-xr-x 2 root root 60 Jan 1 1970 raw
crw-rw-r-- 1 root netdev 10, 58 Apr 29 11:12 rfkill
brw-rw---- 1 root disk 8, 0 Apr 29 11:12 sda
brw-rw---- 1 root disk 8, 1 Apr 29 11:12 sda1
brw-rw---- 1 root disk 8, 2 Apr 29 11:12 sda2
drwxr-xr-x 4 root root 80 Apr 29 11:12 serial
lrwxrwxrwx 1 root root 7 Apr 29 11:12 serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Apr 29 11:12 serial1 -> ttyS0
crw-rw---- 1 root disk 21, 0 Apr 29 11:12 sg0
drwxrwxrwt 2 root root 40 Nov 3 2016 shm
drwxr-xr-x 3 root root 160 Apr 29 11:12 snd
lrwxrwxrwx 1 root root 15 Nov 3 2016 stderr -> /proc/self/fd/2
lrwxrwxrwx 1 root root 15 Nov 3 2016 stdin -> /proc/self/fd/0
lrwxrwxrwx 1 root root 15 Nov 3 2016 stdout -> /proc/self/fd/1
crw-rw-rw- 1 root tty 5, 0 Apr 29 11:12 tty
crw--w---- 1 root tty 4, 0 Apr 29 11:12 tty0
crw--w---- 1 root tty 4, 1 Apr 29 11:12 tty1
crw--w---- 1 root tty 4, 10 Apr 29 11:12 tty10
crw--w---- 1 root tty 4, 11 Apr 29 11:12 tty11
crw--w---- 1 root tty 4, 12 Apr 29 11:12 tty12
crw--w---- 1 root tty 4, 13 Apr 29 11:12 tty13
crw--w---- 1 root tty 4, 14 Apr 29 11:12 tty14
crw--w---- 1 root tty 4, 15 Apr 29 11:12 tty15
crw--w---- 1 root tty 4, 16 Apr 29 11:12 tty16
crw--w---- 1 root tty 4, 17 Apr 29 11:12 tty17
crw--w---- 1 root tty 4, 18 Apr 29 11:12 tty18
crw--w---- 1 root tty 4, 19 Apr 29 11:12 tty19
crw--w---- 1 root tty 4, 2 Apr 29 11:12 tty2
crw--w---- 1 root tty 4, 20 Apr 29 11:12 tty20
crw--w---- 1 root tty 4, 21 Apr 29 11:12 tty21
crw--w---- 1 root tty 4, 22 Apr 29 11:12 tty22
crw--w---- 1 root tty 4, 23 Apr 29 11:12 tty23
crw--w---- 1 root tty 4, 24 Apr 29 11:12 tty24
crw--w---- 1 root tty 4, 25 Apr 29 11:12 tty25
crw--w---- 1 root tty 4, 26 Apr 29 11:12 tty26
crw--w---- 1 root tty 4, 27 Apr 29 11:12 tty27
crw--w---- 1 root tty 4, 28 Apr 29 11:12 tty28
crw--w---- 1 root tty 4, 29 Apr 29 11:12 tty29
crw--w---- 1 root tty 4, 3 Apr 29 11:12 tty3
crw--w---- 1 root tty 4, 30 Apr 29 11:12 tty30
crw--w---- 1 root tty 4, 31 Apr 29 11:12 tty31
crw--w---- 1 root tty 4, 32 Apr 29 11:12 tty32
crw--w---- 1 root tty 4, 33 Apr 29 11:12 tty33
crw--w---- 1 root tty 4, 34 Apr 29 11:12 tty34
crw--w---- 1 root tty 4, 35 Apr 29 11:12 tty35
crw--w---- 1 root tty 4, 36 Apr 29 11:12 tty36
crw--w---- 1 root tty 4, 37 Apr 29 11:12 tty37
crw--w---- 1 root tty 4, 38 Apr 29 11:12 tty38
crw--w---- 1 root tty 4, 39 Apr 29 11:12 tty39
crw--w---- 1 root tty 4, 4 Apr 29 11:12 tty4
crw--w---- 1 root tty 4, 40 Apr 29 11:12 tty40
crw--w---- 1 root tty 4, 41 Apr 29 11:12 tty41
crw--w---- 1 root tty 4, 42 Apr 29 11:12 tty42
crw--w---- 1 root tty 4, 43 Apr 29 11:12 tty43
crw--w---- 1 root tty 4, 44 Apr 29 11:12 tty44
crw--w---- 1 root tty 4, 45 Apr 29 11:12 tty45
crw--w---- 1 root tty 4, 46 Apr 29 11:12 tty46
crw--w---- 1 root tty 4, 47 Apr 29 11:12 tty47
crw--w---- 1 root tty 4, 48 Apr 29 11:12 tty48
crw--w---- 1 root tty 4, 49 Apr 29 11:12 tty49
crw--w---- 1 root tty 4, 5 Apr 29 11:12 tty5
crw--w---- 1 root tty 4, 50 Apr 29 11:12 tty50
crw--w---- 1 root tty 4, 51 Apr 29 11:12 tty51
crw--w---- 1 root tty 4, 52 Apr 29 11:12 tty52
crw--w---- 1 root tty 4, 53 Apr 29 11:12 tty53
crw--w---- 1 root tty 4, 54 Apr 29 11:12 tty54
crw--w---- 1 root tty 4, 55 Apr 29 11:12 tty55
crw--w---- 1 root tty 4, 56 Apr 29 11:12 tty56
crw--w---- 1 root tty 4, 57 Apr 29 11:12 tty57
crw--w---- 1 root tty 4, 58 Apr 29 11:12 tty58
crw--w---- 1 root tty 4, 59 Apr 29 11:12 tty59
crw--w---- 1 root tty 4, 6 Apr 29 11:12 tty6
crw--w---- 1 root tty 4, 60 Apr 29 11:12 tty60
crw--w---- 1 root tty 4, 61 Apr 29 11:12 tty61
crw--w---- 1 root tty 4, 62 Apr 29 11:12 tty62
crw--w---- 1 root tty 4, 63 Apr 29 11:12 tty63
crw--w---- 1 root tty 4, 7 Apr 29 11:12 tty7
crw--w---- 1 root tty 4, 8 Apr 29 11:12 tty8
crw--w---- 1 root tty 4, 9 Apr 29 11:12 tty9
crw-rw-rw- 1 root dialout 166, 0 May 2 23:31 ttyACM0
crw-rw---- 1 root dialout 204, 64 May 2 23:31 ttyAMA0
crw------- 1 root root 5, 3 Apr 29 11:12 ttyprintk
crw-rw---- 1 root dialout 4, 64 Apr 29 11:12 ttyS0
crw-rw-rw- 1 root dialout 188, 0 May 2 23:31 ttyUSB0
lrwxrwxrwx 1 root root 7 Apr 29 11:12 ttyUSB_RS485 -> ttyUSB0
lrwxrwxrwx 1 root root 7 Apr 29 11:12 ttyUSB_ZStick -> ttyACM0
crw------- 1 root root 10, 239 Apr 29 11:12 uhid
crw------- 1 root root 10, 223 Apr 29 11:12 uinput
crw-rw-rw- 1 root root 1, 9 Apr 29 11:12 urandom
crw-rw---- 1 root video 246, 0 Apr 29 11:12 vchiq
crw-rw---- 1 root video 249, 0 Apr 29 11:12 vcio
crw------- 1 root root 250, 0 Apr 29 11:12 vc-mem
crw-rw---- 1 root tty 7, 0 Apr 29 11:12 vcs
crw-rw---- 1 root tty 7, 1 Apr 29 11:12 vcs1
crw-rw---- 1 root tty 7, 2 Apr 29 11:12 vcs2
crw-rw---- 1 root tty 7, 3 Apr 29 11:12 vcs3
crw-rw---- 1 root tty 7, 4 Apr 29 11:12 vcs4
crw-rw---- 1 root tty 7, 5 Apr 29 11:12 vcs5
crw-rw---- 1 root tty 7, 6 Apr 29 11:12 vcs6
crw-rw---- 1 root tty 7, 128 Apr 29 11:12 vcsa
crw-rw---- 1 root tty 7, 129 Apr 29 11:12 vcsa1
crw-rw---- 1 root tty 7, 130 Apr 29 11:12 vcsa2
crw-rw---- 1 root tty 7, 131 Apr 29 11:12 vcsa3
crw-rw---- 1 root tty 7, 132 Apr 29 11:12 vcsa4
crw-rw---- 1 root tty 7, 133 Apr 29 11:12 vcsa5
crw-rw---- 1 root tty 7, 134 Apr 29 11:12 vcsa6
crw------- 1 root root 10, 137 Apr 29 11:12 vhci
crw------- 1 root root 10, 130 Apr 29 11:12 watchdog
crw------- 1 root root 252, 0 Apr 29 11:12 watchdog0
crw-rw-rw- 1 root root 1, 5 Apr 29 11:12 zero
[23:31:55] openhabian@openHABianPi:~$
I have no idea what I´m looking at
Perhaps these also need to have group dialout
ownership?
Maybe. I just dont know how to. I followed the tutorial for setting up symlinks.
This one:
Thank you! There was a PR that resolved the multiple versions of nrjavaserial being used, which may have been the cause but it did not resolve this issue. The start of these issues also seemed to coincide with the zwave binding moving to a different serial transport. I’ll test with an older binding to try and isolate the issue.
No… the issue still occurs if you do not use symlinks.
Following the discussion a special serialhandler is allready integrated in core. Some of the next builds should get it. The actual build #1583 still has this issue (just updated and tested)
In my case after start of OH2.5 opening paperUI, delete Serial Z-Wave Handler, add it again works.
Not nice, but it is a workaround until issue is solved.
In my case, I edit the .thing file from /ttyUSB_ZStick to /ttyACM0. Then the dongle works fine.
After next restart it will fail again, I change the .thing file back to /ttyUSB_ZStick, and it works fine again…
Really odd and quite annoying.
There was a PR to resolve the issue of multiple versions of nrjavaserial being used. This is in the snapshots and does not correct this issue. There is a special nrjavaserial that is built for use with OH which removed liblocdev, but those discussions are tangential to this issue and to the one about multiple versions being used.
I just tested with an older version of the zwave binding and everything started up fine after several OH restarts. Also, the serial port dropdowns continued to display all ports. The issue appears to be related to this PR, which modified the serial transport used by the zwave binding.
Correct - this is what I said previously, although I can’t find the thread. My guess is that there is a startup issue - given that this only seems to be a problem on startup, I think that possibly the provider isn’t available when the binding starts, and therefore it can’t open the port.
That’s a guess though, but given the ESH startup is not well defined, I think it’s a good possibility.
In addition, there appears to be some kind of conflict in the USB discovery service after the zwave binding is manually restarted, since the ports listed in the dropdown (for all bindings using serial) disappear except for the one used by zwave (at least that is what I am seeing). Possibly due to using different serial transports? It’s probably time to replace openhab-transport-serial in all bindings with openhab-core-io-transport-serial, since TMK there is no reason for OH to have both.
I’m not an expert. I did have a similar problem on start-up after I delete my tmp and cache directories. I’m on OH 2.4 but am using a zwave 2.5 snapshot, so it might not be the same issue. Anyway I found a suggestion on the forum that worked for me. Go into the console and type; feature:install openhab-transport-serial. Everything came back.
In a separate post I was wondering if there is a OH file I can place this command into because I get a lot of errors until I can get into the console after a start-up and issue the above command.
The issue reported here is different. If you are running a recent snapshot version of the binding, you will find that zwave will not find the serial port after OH restarts and you will need to restart the binding to get it working. The easiest way I have found to do this is to open Habmin and change the name of the controller.
What you are describing is due to binding dependencies not being automatically resolved when the binding is manually installed, so the serial transport also needs to be manually installed. You could automate this by running my script in a startup rule.
@ffr, I change the title of your topic… hopefully this is more accurate. Or are you not using the snapshot version of the zwave binding?
Here is an issue to track…
I would like to move this to the core - this is not a ZWave issue, but is related to the serial provider as seen from the logs below -:
2019-05-02 19:45:43.586 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-05-02 19:45:43.603 [WARN ] [erial.internal.SerialPortManagerImpl] - No SerialPortProvider found for: /dev/ttyACM0
I agree on this…
As I wrote above, I have this issue with my RS485 dongle as well… Infact it´s a nightmare with all my USB devices, No matter what I connect, its pure random which will fail and which will succeed when restarting openhab/rpi. Except for my external SSD drive, my 4 port active USB hub, and my Zigbee hat, which is connected to PIO interface.
My second Zigbee dongle (used for sniffing), Zwave dongle, Wmbus dongle and RS485 dongle is a nightmare. Atm I have disconnected the extra Zigbee dongle and the Wmbus dongle (Wmbus binding doesnt work anyway). Then I “only” have problems with the RS485 and zwave when restarting.
This looks to be resolved in S1585. However, read this comment in the issue, or more importantly the responses, as there may be some limitations to manual installation of the zwave and zigbee bindings. Hopefully, I’m completely wrong!
Edit: I was using my install script and the directories had changed. Manual installs are still possible! Latest Zwave binding missing module?
hi, i’m running in a (i guess) related issue when moving from 1566 to 1587…i have zwave which works fine, but jeelink stops working and the existing port in linux /dev/ttyUSB1 can not be selected anymore from PaperUI/habmin…
Any idea how to fix it? Could/is this related to this discussion , as it only seems to discuss zwave/zigbee sticks?
