Yesterday a rule started ignoring the condition script contained in the javascript rule. The rule ran several times yesterday morning and this morning as the temperature in the living room was frequently changing. Here’s some snippets from the openhablog during the times the rule ran:
2025-07-02 06:10:59.166 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for LivingroomSensor_Temperature
2025-07-02 06:10:59.166 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Temperatures
2025-07-02 06:10:59.167 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger '4' of rule 'Bedroom_Temp_Control' is triggered.
2025-07-02 06:10:59.167 [DEBUG] [.monitor.internal.metrics.RuleMetric] - Rule Bedroom_Temp_Control RUNNING - updating metric.
2025-07-02 06:10:59.167 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:10:59.168 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:10:59.168 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:10:59.168 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/command.
2025-07-02 06:10:59.169 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:10:59.169 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating command '100' for item 'Big_Window' to handler for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:10:59.169 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/state.
2025-07-02 06:10:59.169 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule 'Bedroom_Temp_Control' is executed.
2025-07-02 06:10:59.169 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Big_Window
2025-07-02 06:10:59.169 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandler" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:10:59.169 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ChannelUID" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:10:59.169 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.Thing" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:10:59.170 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandlerCallback" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:10:59.170 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ThingStatusInfo" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:10:59.170 [DEBUG] [nternal.common.InvocationHandlerSync] - Already in a safe-call context, executing 'ThingHandler.handleCommand()' directly on 'org.openhab.binding.homematic.internal.handler.HomematicThingHandler@27506789'.
2025-07-02 06:10:59.171 [DEBUG] [ternal.handler.HomematicThingHandler] - Received command '100' for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:10:59.171 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint '00165BE99E5220:2#LEVEL' with value '0.0' to gateway with id '3014F711A0001F9A49923603' using rxMode 'DEFAULT'
2025-07-02 06:10:59.171 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'LR_Humidity' with state '56 %' as '{"name":"LR_Humidity","state":"org.openhab.core.library.types.QuantityType@@@56 %","timestamp":"Jul 2, 2025, 6:10:59 AM"}' in MapDB database
2025-07-02 06:10:59.179 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Big_Window' with state '100' as '{"name":"Big_Window","state":"org.openhab.core.library.types.PercentType@@@100","timestamp":"Jul 2, 2025, 6:10:59 AM"}' in MapDB database
2025-07-02 06:20:56.652 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/LivingroomSensor_Temperature/state.
2025-07-02 06:20:56.652 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for LivingroomSensor_Temperature
2025-07-02 06:20:56.653 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Temperatures
2025-07-02 06:20:56.653 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger '4' of rule 'Bedroom_Temp_Control' is triggered.
2025-07-02 06:20:56.653 [DEBUG] [.monitor.internal.metrics.RuleMetric] - Rule Bedroom_Temp_Control RUNNING - updating metric.
2025-07-02 06:20:56.653 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:20:56.654 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking value color for widget 'LR Temperature [%.0f °C]'.
2025-07-02 06:20:56.654 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:20:56.655 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - value color for widget 'LR Temperature [%.0f °C]' is 'orange'.
2025-07-02 06:20:56.655 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:20:56.656 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0108 to subscription 384c319b-0e47-48dd-bbc1-6c600d617a5a.
2025-07-02 06:20:56.656 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/command.
2025-07-02 06:20:56.656 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:20:56.656 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating command '100' for item 'Big_Window' to handler for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:20:56.657 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/state.
2025-07-02 06:20:56.657 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule 'Bedroom_Temp_Control' is executed.
2025-07-02 06:20:56.657 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Big_Window
2025-07-02 06:20:56.657 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandler" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:20:56.658 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ChannelUID" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:20:56.658 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.Thing" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:20:56.658 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandlerCallback" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:20:56.658 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ThingStatusInfo" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:20:56.659 [DEBUG] [nternal.common.InvocationHandlerSync] - Already in a safe-call context, executing 'ThingHandler.handleCommand()' directly on 'org.openhab.binding.homematic.internal.handler.HomematicThingHandler@27506789'.
2025-07-02 06:20:56.659 [DEBUG] [ternal.handler.HomematicThingHandler] - Received command '100' for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:20:56.659 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint '00165BE99E5220:2#LEVEL' with value '0.0' to gateway with id '3014F711A0001F9A49923603' using rxMode 'DEFAULT'
2025-07-02 06:20:56.662 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'LivingroomSensor_Temperature' with state '25.6 °C' as '{"name":"LivingroomSensor_Temperature","state":"org.openhab.core.library.types.QuantityType@@@25.6 °C","timestamp":"Jul 2, 2025, 6:20:56 AM"}' in MapDB database
2025-07-02 06:20:56.669 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Temperatures' with state '25.52857142857142857142857142857143' as '{"name":"Temperatures","state":"org.openhab.core.library.types.DecimalType@@@25.52857142857142857142857142857143","timestamp":"Jul 2, 2025, 6:20:56 AM"}' in MapDB database
2025-07-02 06:20:56.669 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Big_Window' with state '100' as '{"name":"Big_Window","state":"org.openhab.core.library.types.PercentType@@@100","timestamp":"Jul 2, 2025, 6:20:56 AM"}' in MapDB database
2025-07-02 06:33:10.662 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/LivingroomSensor_Temperature/state.
2025-07-02 06:33:10.662 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for LivingroomSensor_Temperature
2025-07-02 06:33:10.662 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Temperatures
2025-07-02 06:33:10.663 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger '4' of rule 'Bedroom_Temp_Control' is triggered.
2025-07-02 06:33:10.663 [DEBUG] [.monitor.internal.metrics.RuleMetric] - Rule Bedroom_Temp_Control RUNNING - updating metric.
2025-07-02 06:33:10.663 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:33:10.665 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:33:10.665 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking value color for widget 'LR Temperature [%.0f °C]'.
2025-07-02 06:33:10.666 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - value color for widget 'LR Temperature [%.0f °C]' is 'orange'.
2025-07-02 06:33:10.666 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:33:10.667 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/command.
2025-07-02 06:33:10.667 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0108 to subscription 3ee44cf7-504c-4ea5-8590-41b3f0eccd5b.
2025-07-02 06:33:10.667 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:33:10.668 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule 'Bedroom_Temp_Control' is executed.
2025-07-02 06:33:10.668 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating command '100' for item 'Big_Window' to handler for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:33:10.668 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/state.
2025-07-02 06:33:10.669 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Big_Window
2025-07-02 06:33:10.669 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandler" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:33:10.670 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ChannelUID" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:33:10.670 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.Thing" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:48:40.405 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Double) value '25.0' for '000EA0C99DCC2D:1#ACTUAL_TEMPERATURE' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.405 [DEBUG] [converter.type.AbstractTypeConverter] - Converting datapoint '000EA0C99DCC2D:1#ACTUAL_TEMPERATURE' (dpType='FLOAT', dpUnit='°C', dpValue='25.0') with QuantityTypeConverter
2025-07-02 06:48:40.405 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/LivingroomSensor_Temperature/state.
2025-07-02 06:48:40.405 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for LivingroomSensor_Temperature
2025-07-02 06:48:40.406 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Temperatures
2025-07-02 06:48:40.406 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger '4' of rule 'Bedroom_Temp_Control' is triggered.
2025-07-02 06:48:40.406 [DEBUG] [.monitor.internal.metrics.RuleMetric] - Rule Bedroom_Temp_Control RUNNING - updating metric.
2025-07-02 06:48:40.406 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:48:40.407 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:48:40.407 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 06:48:40.408 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/command.
2025-07-02 06:48:40.408 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 06:48:40.408 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule 'Bedroom_Temp_Control' is executed.
2025-07-02 06:48:40.409 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/state.
2025-07-02 06:48:40.409 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating command '100' for item 'Big_Window' to handler for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:48:40.409 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Big_Window
2025-07-02 06:48:40.409 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandler" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:48:40.409 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ChannelUID" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:48:40.409 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.Thing" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:48:40.410 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandlerCallback" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:48:40.410 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ThingStatusInfo" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 06:48:40.411 [DEBUG] [nternal.common.InvocationHandlerSync] - Already in a safe-call context, executing 'ThingHandler.handleCommand()' directly on 'org.openhab.binding.homematic.internal.handler.HomematicThingHandler@27506789'.
2025-07-02 06:48:40.412 [DEBUG] [ternal.handler.HomematicThingHandler] - Received command '100' for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 06:48:40.412 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint '00165BE99E5220:2#LEVEL' with value '0.0' to gateway with id '3014F711A0001F9A49923603' using rxMode 'DEFAULT'
2025-07-02 06:48:40.415 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'LivingroomSensor_Temperature' with state '25 °C' as '{"name":"LivingroomSensor_Temperature","state":"org.openhab.core.library.types.QuantityType@@@25 °C","timestamp":"Jul 2, 2025, 6:48:40 AM"}' in MapDB database
2025-07-02 06:48:40.426 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Temperatures' with state '25.32857142857142857142857142857143' as '{"name":"Temperatures","state":"org.openhab.core.library.types.DecimalType@@@25.32857142857142857142857142857143","timestamp":"Jul 2, 2025, 6:48:40 AM"}' in MapDB database
2025-07-02 06:48:40.426 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Big_Window' with state '100' as '{"name":"Big_Window","state":"org.openhab.core.library.types.PercentType@@@100","timestamp":"Jul 2, 2025, 6:48:40 AM"}' in MapDB database
2025-07-02 06:48:40.559 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for '00179BE9937DF3:0#CONFIG_PENDING' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.560 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for '00179BE9937DF3:0#UNREACH' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.560 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value '10.10.7.7' for '00179BE9937DF3:0#IP_ADDRESS' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.564 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for '00165BE99E5220:0#CONFIG_PENDING' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.565 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for '00165BE99E5220:0#UNREACH' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.570 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '0' for '00165BE99E5220:2#SECTION_STATUS' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.570 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '1' for '00165BE99E5220:2#LEVEL_2_STATUS' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.571 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value '' for '00165BE99E5220:2#LEVEL_2' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.571 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '0' for '00165BE99E5220:2#LEVEL_STATUS' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.571 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '1' for '00165BE99E5220:2#PROCESS' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.571 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Double) value '1.0' for '00165BE99E5220:2#LEVEL' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.572 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '2' for '00165BE99E5220:2#SECTION' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.572 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/state.
2025-07-02 06:48:40.572 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '2' for '00165BE99E5220:2#ACTIVITY_STATE' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 06:48:40.572 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Discarding value 1.0 for item Big_Window with timestamp 1751431720 because a new value (0.0) arrived with the same timestamp.
2025-07-02 06:48:40.572 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for GF_Rolladen
2025-07-02 06:48:40.572 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Big_Window
2025-07-02 06:48:40.594 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'GF_Rolladen' with state '0' as '{"name":"GF_Rolladen","state":"org.openhab.core.library.types.PercentType@@@0","timestamp":"Jul 2, 2025, 6:48:40 AM"}' in MapDB database
2025-07-02 06:48:40.594 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Big_Window' with state '0' as '{"name":"Big_Window","state":"org.openhab.core.library.types.PercentType@@@0","timestamp":"Jul 2, 2025, 6:48:40 AM"}' in MapDB database
2025-07-02 08:32:26.385 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for '000EA0C99DCC2D:1#BOOST_MODE' from gateway with id '3014F711A0001F9A49923603'
2025-07-02 08:32:26.385 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/LivingroomSensor_Temperature/state.
2025-07-02 08:32:26.386 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for LivingroomSensor_Temperature
2025-07-02 08:32:26.386 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger '4' of rule 'Bedroom_Temp_Control' is triggered.
2025-07-02 08:32:26.386 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Temperatures
2025-07-02 08:32:26.387 [DEBUG] [.monitor.internal.metrics.RuleMetric] - Rule Bedroom_Temp_Control RUNNING - updating metric.
2025-07-02 08:32:26.387 [DEBUG] [.handler.AbstractScriptModuleHandler] - Executing pre-compiled script of rule with UID 'Bedroom_Temp_Control'
2025-07-02 08:32:26.387 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 08:32:26.388 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/command.
2025-07-02 08:32:26.389 [DEBUG] [.internal.OpenhabGraalJSScriptEngine] - Lock released.
2025-07-02 08:32:26.389 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating command '100' for item 'Big_Window' to handler for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 08:32:26.389 [DEBUG] [or.internal.metrics.EventCountMetric] - Received event on topic openhab/items/Big_Window/state.
2025-07-02 08:32:26.389 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule 'Bedroom_Temp_Control' is executed.
2025-07-02 08:32:26.389 [DEBUG] [pdb.internal.MapDbPersistenceService] - store called for Big_Window
2025-07-02 08:32:26.389 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandler" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 08:32:26.390 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ChannelUID" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 08:32:26.390 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.Thing" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 08:32:26.390 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.binding.ThingHandlerCallback" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 08:32:26.390 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 010500 to subscription 382e722d-e5f6-4c43-961b-ec0633d4bc73.
2025-07-02 08:32:26.390 [DEBUG] [.internal.common.CombinedClassLoader] - Loaded class "org.openhab.core.thing.ThingStatusInfo" by classloader "org.eclipse.osgi.internal.loader.EquinoxClassLoader@3179035d[org.openhab.core.thing:4.3.5(id=221)]" for "[interface org.openhab.core.thing.binding.ThingHandler]"
2025-07-02 08:32:26.391 [DEBUG] [nternal.common.InvocationHandlerSync] - Already in a safe-call context, executing 'ThingHandler.handleCommand()' directly on 'org.openhab.binding.homematic.internal.handler.HomematicThingHandler@27506789'.
2025-07-02 08:32:26.391 [DEBUG] [ternal.handler.HomematicThingHandler] - Received command '100' for channel 'homematic:HmIPW-DRBL4:3014F711A0001F9A49923603:00165BE99E5220:2#LEVEL'
2025-07-02 08:32:26.391 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint '00165BE99E5220:2#LEVEL' with value '0.0' to gateway with id '3014F711A0001F9A49923603' using rxMode 'DEFAULT'
2025-07-02 08:32:26.396 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'LivingroomSensor_Temperature' with state '25.3 °C' as '{"name":"LivingroomSensor_Temperature","state":"org.openhab.core.library.types.QuantityType@@@25.3 °C","timestamp":"Jul 2, 2025, 8:32:26 AM"}' in MapDB database
2025-07-02 08:32:26.403 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Big_Window' with state '100' as '{"name":"Big_Window","state":"org.openhab.core.library.types.PercentType@@@100","timestamp":"Jul 2, 2025, 8:32:26 AM"}' in MapDB database
2025-07-02 08:32:26.403 [DEBUG] [pdb.internal.MapDbPersistenceService] - Stored 'Temperatures' with state '25.14285714285714285714285714285714' as
Here is the yaml of the rule in question:
configuration: {}
triggers:
- id: "4"
configuration:
itemName: LivingroomSensor_Temperature
conditions:
- inputs: {}
configuration:
type: application/javascript
script: |-
items.LivingroomSensor_Temperature.state > 24 ;
items.Sun_Position.state > 180;
items.Sun_Position.state < 185;
items.Current_Cloudiness.state < 0.5;
type: script.ScriptCondition
actions:
- inputs: {}
configuration:
type: application/javascript;version=ECMAScript-2021
script: >
items.getItem("Bedroom_Shutters").sendCommandIfDifferent("20");
items.getItem("Big_Window").sendCommandIfDifferent(100)
setTimeout(()=> {items.getItem("BigWindow_Stop").sendCommand("ON");},
21000)
type: script.ScriptAction
Other rules are running as well and the conditions are being checked.
