Platform information:
- Hardware: Pi 4 / 8 GB
- OS: buster w/openhabian install on top. uname -a
- Linux pi-home 5.10.92-v7l+ #1514 SMP Mon Jan 17 17:38:03 GMT 2022 armv7l GNU/Linux
- Java Runtime Environment: java --version
- openjdk 11.0.14 2022-01-18
- OpenJDK Runtime Environment (build 11.0.14+9-post-Raspbian-1deb11u1)
- OpenJDK Server VM (build 11.0.14+9-post-Raspbian-1deb11u1, mixed mode)
- openHAB version: 3.2.0 (openhab-cli info)
I enabled a lot of debugging logs trying to find the source of a repeating INFO-level error. Logging seems to have stopped working. I don’t care for an answer since I’m about to upgrade to 3.3 to get rid of that INFO-level error. This is just a heads up to anyone in development who may be monitoring these threads.
I stripped all but the last .gz files from the output for brevity.
pi@pi-home:/var/log/openhab $ ls -l
total 5092
-rw-rw-r-- 1 openhab openhab 0 Feb 10 22:05 audit.log
-rw-r--r-- 1 openhab openhab 358656 Mar 16 20:36 events.log
-rw-r--r-- 1 openhab openhab 943 Feb 25 22:46 events.log.7.gz
-rw-r--r-- 1 openhab openhab 2213404 Mar 16 20:36 openhab.log
-rw-r--r-- 1 openhab openhab 1090122 Mar 5 05:17 openhab.log.7.gz
pi@pi-home:/var/log/openhab $ tail events.log
2022-03-06 05:04:12.546 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tplinksmarthome:kl135:8d69560dcd' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
2022-03-06 05:04:44.250 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HallOverhead_Color' changed from UNDEF to 306,90,0
pi@pi-home:/var/log/openhab $ date
Wed 16 Mar 2022 08:37:29 PM MDT
There are about 10 days of output missing between the current date/time, the matching timestamp on the file, and the file content. Leaving aside the tons of DEBUG output, that lightbulb toggles state like that several times per hour and there’s also the every-minute MQTT error that started all this.
openHAB has been running the entire time:
pi@pi-home:/var/log/openhab $ sudo service openhab status
Active: active (running) since Fri 2022-02-25 22:45:59 MST; 2 weeks 4 days ago
Also from that service status:
Mar 06 05:38:24 pi-home karaf[1238]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to write to stream /var/log/openhab/openhab.log for appender LOGFILE
Mar 06 05:38:24 pi-home karaf[1238]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : An exception occurred processing Appender LOGFILE
Nothing is full:
pi@pi-home:/var/log/openhab $ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 27892756 13125480 13327328 50% /
devtmpfs 4035980 0 4035980 0% /dev
tmpfs 4069772 0 4069772 0% /dev/shm
tmpfs 1627912 2068 1625844 1% /run
tmpfs 5120 8 5112 1% /run/lock
/dev/mmcblk0p6 258094 49438 208657 20% /boot
/dev/zram1 330424 14620 290716 5% /opt/zram/zram1
overlay1 330424 14620 290716 5% /var/lib/openhab/persistence
/dev/zram2 330424 8552 296784 3% /opt/zram/zram2
overlay2 330424 8552 296784 3% /var/lib/influxdb
/dev/zram3 429288 306140 90892 78% /opt/zram/zram3
overlay3 429288 306140 90892 78% /var/log
tmpfs 813952 20 813932 1% /run/user/1000
