Is it possible to disable request.log short of commenting out this whole section in jetty.xml?
<!-- Configure Request Log -->
<!-- Request logs may be configured for the entire server here, -->
<!-- or they can be configured for a specific web app in a -->
<!-- contexts configuration (see $(jetty.home)/contexts/test.xml -->
<!-- for an example). -->
<Ref id="RequestLog">
<Set name="requestLog">
<New id="RequestLogImpl" class="org.eclipse.jetty.server.NCSARequestLog">
<Set name="filename"><SystemProperty name="jetty.logs" default="./logs"/>/yyyy_mm_dd.request.log</Set>
<Set name="filenameDateFormat">yyyy_MM_dd</Set>
<Set name="retainDays">90</Set>
<Set name="append">true</Set>
<Set name="extended">false</Set>
<Set name="logCookies">false</Set>
<Set name="LogTimeZone">GMT</Set>
</New>
</Set>
</Ref>
I like to be logged into myopenhab while i’m at work and the webpage sends a request every few seconds. I would like to minimize writes on my raspberry pi.
