Looking for some guidance around if its possible to set up an energy sensor to work with OH2
i have picked up a few parts hoping a could get this working and have already hit a wall
equipment i was looking at using
Current Transformer AC current sensor 100A SCT-013-000
ESP8266 Mains Power Sensor
Wemos D1 Mini
as set up in the link - ESP8266 Mains Power Sensor by Dimwit-Dave - Thingiverse
i normal content a sensor with Esp easy and use MQTT however cant this time so found this code but the is no way to add user name and password for my MQTT Broker?
/* Connection detials for WiFi and board functions
// Select Static IP Mode, uncomment below to enable
//#define STATIC_IP
IPAddress ip(192, 168, 1, 33);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// Add your Wifi details below
const char* SSID_1 = "AP";
const char* Password_1 = "Password";
const char* SSID_2 = "AP";
const char* Password_2 = "Password";
const char* SSID_3 = "AP";
const char* Password_3 = "Password";
const char* SSID_4 = "AP";
const char* Password_4 = "Password";
// MQTT Broker
const char* mqtt_server = "192.168.1.10";
// MQTT Topics
const char* InStatus = "Power/Status";
const char* InControl = "Power/Control";
String Broadcast_All = "*ALL"; // Message used to broadcast to all devices subscribed to above topic
// Heatbeat items
#define Heartbeat_Range 99 // Event count max value
#define Heatbeat 1000 // Heartbeat timer value, in mS
// Watchdog items
volatile int Watchdog_Timout = 1200; // Time in seconds before watchdog times out, 1200 = 1200 seconds or 20 minutes
// Heatbeat timer
int Heart_Value = 0; // Timer
long LastMsg = 0; // Message sent counter
// Custom default values
String WiFi_SSID = "None"; // SSID string
String My_MAC = ""; // MAC address, tobe Read from ESP8266
char MAC_array[13] = "000000000000"; // Better MAC definition
//String Mode = "Off"; // Default mode
volatile int Report_Request = 0; // Set to 1 if report required
String Event = "Boot"; // Default
// I/O
#define Status_LED 2 // D4
#define Status_LED_On digitalWrite(Status_LED, HIGH)
#define Status_LED_Off digitalWrite(Status_LED, LOW)
// Power monitor items
double Calib = 1;//10.545662
double Kilos;
unsigned long StartMillis;
unsigned long EndMillis;
double RMSCurrent;
int RMSPower;
int PeakPower;
void ReadPower () // Method to read information from CTs
int Current = 0;
int MaxCurrent = 0;
int MinCurrent = 1023;
int PeakCurrent = 0;
// Needs to sample for at least one and half mains cycles or > 30mS
for (int j = 0 ; j <= 600 ; j++)
// digitalWrite(D8, HIGH);
Current = analogRead(A0); //Reads A/D input and records maximum and minimum current
// digitalWrite(D8, LOW);
if (Current >= MaxCurrent)
MaxCurrent = Current;
if (Current <= MinCurrent)
MinCurrent = Current;
} // End of samples loop
PeakCurrent = MaxCurrent - MinCurrent;
RMSCurrent = PeakCurrent;
// http://www.referencedesigner.com/rfcal/vrms-to-vpeak-conversion.php
// RMSCurrent = (PeakCurrent * 0.3535) / Calib; //Calculates RMS current based on maximum value and scales according to calibration
// RMSPower = 248 * RMSCurrent; //Calculates RMS Power Assuming Voltage 240VAC, change to 110VAC accordingly
} // End of function
full code here GitHub - Mottramlabs/MQTT-Power-Sensor
can anyone give me any advise or other way to do this as i have been researching for a few days and still haven’t got an answer
Chris
