Hello is there a way to get the Powerinfomation from the BT-PSS? At this point you only have the switch to turn on/off
I would like to see the Powerinformation inside of Openhab
How did you added this medion switch? While scanning the switch will be also found as BT-PSS, nut failed and cannot be switched.
