I’m new to openhab 2 and while the RFCom went well, I am struggling to get this one working.
I have the PowerMax Complete with the serial module installed. The serial module is connected to a serial ethernet device (tcp raw server mode). I am using the TCP connection on openHab 2 (Raspberry Pi version, Visonic 1.9.0 snapshot)
The logs show:
2016-12-18 19:15:20.705 [INFO ] [b.core.service.AbstractActiveService] - PowerMax Refresh Service has been started
2016-12-18 19:15:20.883 [INFO ] [ng.powermax.internal.PowerMaxBinding] - PowerMax alarm binding: TCP connection (IP 172.23.41.220 port 2011): connected
2016-12-18 19:15:33.181 [INFO ] [ng.powermax.internal.PowerMaxBinding] - PowerMax alarm binding: running in Powerlink mode
but I can’t get beyond that. Nothing shows up as Things. I have tried editing the visonic config file (as well as Paper UI) and tried adding items as per the wiki. Items then show up under items in PaperUi but they don’t seem to be connected to anything or show up anywhere else.
Still in progress. I worked on it this week trying to fix the last problems. One might be not new and maybe already existing in OH1: at OH startup, the reading of all the panel setup is partially failing.
I improved the zone discovery.
Documentation is not yet written.
My code is already pushed in my GitHub but not my last version.
I will try to put this as my top priority.
Sounds nice. Since I moved to OH2, I’m having some issues with my rules. They false trigger every time i Arm the house now. It’s the Powermax_partition_alarm who has started to trigger when i arm my house.
How are you people using rules to activate “true” alarms?
This one gets the entrydelay. So if my phone is at home when entrydelay it disarms.
rule "Huslarm"
Item Powermax_partition_arm_mode changed to EntryDelay
alarm = 1 // I need to set this for the alarm to be activated if entrydelay has been triggerd.
sendCommand(Powermax_EntryDelay, ON)
logInfo( "Alarm system", "Entrydelay on")
if(HouseJustArrived.state == ON) {
sendCommand(Powermax_partition_arm_mode, "Disarmed")
rule "Huslarm"
Item Powermax_partition_alarm changed to ON
alarm = 1
logInfo( "Alarm system", "alarm = 1")
if((Powermax_zone1_status.state==ON) && (Powermax_EntryDelay.state==OFF) && (Powermax_partition_armed==ON)) {
sendCommand(Powermax_Alarm, ON)
pushover("Alarm!! Movement in the living room", 2)
rule "Huslarm"
Item Powermax_partition_arm_mode changed to Armed
if(alarm == 1) {
pushover("Alarm in the house!!", 2)
if(Powermax_Alarm.state!=ON) { sendCommand(Powermax_Alarm, ON) }
logInfo( "Alarm system", "Entredelay larm on")
else {
var String command =Powermax_partition_status.state.toString.toLowerCase
if (command.contains("armed away")) {
if(HouseMode.state!=2) { sendCommand(HouseMode, 2) }
pushover("Alarm is armed", -2)
rule "Alarm disarms"
Item Powermax_partition_arm_mode changed to Disarmed
createTimer(now.plusSeconds(3)) [|
if(Powermax_Alarm.state==ON) {
if(Powermax_EntryDelay!=OFF) { sendCommand(Powermax_EntryDelay, OFF) }
if(Powermax_Alarm.state!=OFF) { sendCommand(Powermax_Alarm, OFF) }
alarm = 0
logInfo( "Alarm system", "Alarm reseted")
pushover("Alarm reseted.", 0)
else {
alarm = 0
if(HouseMode.state!=1) { sendCommand(HouseMode, 1) }
This is my log file. When the alarm actually works when a door is opened and entrydelay is started and it runs out.
When the system goes to EntryDelay i trigger a ‘alarm = 1’. If the system disarms in the entrydelay time window the ‘alarm’ is set to 0. And when the time runs out (without disarm) the partition is set to “armed” again, which means an alarm has triggerd.
Well actually my problem does not always occur, I need to investigate further why it does false alarm, something to do with ‘alarm = 0’ not being set.
2017-02-13 11:14:11.643 [ItemStateChangedEvent ] - Powermax_zone29_status2 changed from CLOSED to OPEN
2017-02-13 11:14:11.649 [ItemStateChangedEvent ] - Powermax_zone29_status changed from OFF to ON
2017-02-13 11:14:11.704 [ItemStateChangedEvent ] - Powermax_partition_status changed from Armed Away, Ready to Entry Delay, Not ready, Open in Zone 29, Status changed, Alarm event
2017-02-13 11:14:11.710 [ItemStateChangedEvent ] - Powermax_partition_alarm changed from OFF to ON
2017-02-13 11:14:11.717 [ItemStateChangedEvent ] - Powermax_zone29_last_trip changed from 2017-02-12T17:39:33.000+0100 to 2017-02-13T11:14:11.000+0100
2017-02-13 11:14:11.725 [ItemStateChangedEvent ] - Powermax_partition_ready changed from ON to OFF
2017-02-13 11:14:11.731 [ItemStateChangedEvent ] - Powermax_partition_arm_mode changed from Armed to EntryDelay
2017-02-13 11:14:11.753 [ItemCommandEvent ] - Item 'Powermax_EntryDelay' received command ON
2017-02-13 11:14:11.759 [ItemStateChangedEvent ] - Powermax_EntryDelay changed from OFF to ON
2017-02-13 11:14:12.052 [ItemStateChangedEvent ] - Powermax_partition_status changed from Entry Delay, Not ready, Open in Zone 29, Status changed, Alarm event to Entry Delay, Not ready
2017-02-13 11:14:12.055 [ItemStateChangedEvent ] - Powermax_partition_alarm changed from ON to OFF
2017-02-13 11:14:14.293 [ItemStateChangedEvent ] - Powermax_partition_status changed from Entry Delay, Not ready to Entry Delay, Ready, Closed in Zone 29
2017-02-13 11:14:14.297 [ItemStateChangedEvent ] - Powermax_partition_ready changed from OFF to ON
2017-02-13 11:14:32.049 [ItemStateChangedEvent ] - Powermax_partition_status changed from Entry Delay, Ready, Closed in Zone 29 to Entry Delay, Ready, Last 10 seconds
2017-02-13 11:14:41.050 [ItemStateChangedEvent ] - Powermax_partition_status changed from Entry Delay, Ready, Last 10 seconds to Armed Away, Ready, Status changed
2017-02-13 11:14:41.055 [ItemStateChangedEvent ] - Powermax_partition_arm_mode changed from EntryDelay to Armed
2017-02-13 11:14:41.682 [ItemCommandEvent ] - Item 'Powermax_Alarm' received command ON // Alarm goes out to the phone.
2017-02-13 11:15:12.118 [ItemStateChangedEvent ] - Powermax_partition_status changed from Armed Away, Ready, Status changed to Armed Away, Ready, Alert in memory
Just startede with Openhab. so it is a steep learning curve .I had my Powermax on a Vera before.
From the examples above, i am able to get the powermax connect with my rasp pi. And I can arm and disarm without a code.
Is it possible to have a keypad and then you have to type in a pin before you are allowed to disarm?
// Disarm alarm
rule "AlarmDisarm"
Item AlarmKeypad received update
if(AlarmKeypad.state==“KODE”)
sendCommand(Powermax_partition_armed, OFF)
This is not using the pin code in powermax, but it uses the pin that you define in the rule. So if you dont enter one of the codes in the rule, then the alarm will not diaarm.
Also remember to allow disarm in the powermax openhab binding settings.
@Lolodomo,
have you tested the tcp connection also? I’m buying a powermax pro and I’d like to add it to openhab with a tcp connection, but if it is not tested or not working, I will buy the serial expansion card .
Thank you in advance.
Okey, I’m new to this binding. Just hoked up my PowerMaster 10 G2 to Openhab with a TTL-USB device. As what I can se I do have communication with the PM. I have followed the instruction from the documentation. I can see that may Serial and so on i read.
But it is from here that I’m not sure how to go on. I don’t get any respons from PIR’s, or door sensors. Trying to read event logs don’t give any thing. Is this due to PowerMaster 10 not beeing compatible, or is it my conf/setup thats not correct?
Are there any settings in the CA/panel that has to be changed in order for the “Powerlink” to go fully active?
As you already got the information you are showing, I think the Powerlink mode is working as expected.
What about the items relative to arm mode ? Are they updated when you arm and disarm your system ?
Maybe your items for sensors are defined with the wrong zone number ?
I could advice to move to the 2.0 version of the bindings as it includes the automatic discovery of zones but it is not yet fully stable and I have not yet released it. But I fixed 2 little bugs yesterday and I should release it soon now.
