BigCol
(BigCol)
March 14, 2020, 6:02pm
1
Last night my Powermax Complete stopped comminucating with openhab.
I’ve increased the logging level and can see the Download request, but can’t see the data coming back.
I’m running 2.5 on Windows 10 and using one of these to connect the 2 devices.
From the logs:
2020-03-14 17:40:52.049 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Powermax job...
2020-03-14 17:40:52.049 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - trying to reconnect...
2020-03-14 17:40:52.049 [DEBUG] [al.connector.PowermaxSerialConnector] - close(): Closing Serial Connection
2020-03-14 17:40:52.049 [DEBUG] [internal.connector.PowermaxConnector] - cleanup(): cleaning up Connection
2020-03-14 17:40:52.050 [DEBUG] [internal.connector.PowermaxConnector] - cleanup(): Connection Cleanup
2020-03-14 17:40:52.050 [DEBUG] [al.connector.PowermaxSerialConnector] - close(): Serial Connection closed
2020-03-14 17:40:52.050 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - closeConnection(): disconnected
2020-03-14 17:40:52.053 [DEBUG] [al.connector.PowermaxSerialConnector] - open(): Opening Serial Connection
2020-03-14 17:40:52.066 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - openConnection(): connected
2020-03-14 17:40:52.066 [DEBUG] [ernal.connector.PowermaxReaderThread] - Data listener started
2020-03-14 17:40:52.068 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel system_status
2020-03-14 17:40:52.068 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel system_armed
2020-03-14 17:40:52.068 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel arm_mode
2020-03-14 17:40:52.068 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel alarm_active
2020-03-14 17:40:52.068 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel trouble
2020-03-14 17:40:52.077 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:7
2020-03-14 17:40:52.079 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:7 (bridge ONLINE)
2020-03-14 17:40:52.080 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:9
2020-03-14 17:40:52.080 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:7 (zone number 7 not paired)
2020-03-14 17:40:52.081 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:9 (bridge ONLINE)
2020-03-14 17:40:52.082 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:9 (zone number 9 not paired)
2020-03-14 17:40:52.083 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:1
2020-03-14 17:40:52.084 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:8
2020-03-14 17:40:52.084 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:6
2020-03-14 17:40:52.085 [DEBUG] [internal.message.PowermaxCommManager] - sendMessage(): add message in queue (type DOWNLOAD)
2020-03-14 17:40:52.086 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:8 (bridge ONLINE)
2020-03-14 17:40:52.086 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:6 (bridge ONLINE)
2020-03-14 17:40:52.088 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:6 (zone number 6 not paired)
2020-03-14 17:40:52.085 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:1 (bridge ONLINE)
2020-03-14 17:40:52.087 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:8 (zone number 8 not paired)
2020-03-14 17:40:52.088 [DEBUG] [internal.message.PowermaxCommManager] - sendMessage(): sending DOWNLOAD message 0D2400004F48000000000000000A
2020-03-14 17:40:52.089 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:1 (zone number 1 not paired)
2020-03-14 17:40:52.094 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:4
2020-03-14 17:40:52.094 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:5
2020-03-14 17:40:52.096 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:5 (bridge ONLINE)
2020-03-14 17:40:52.096 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:4 (bridge ONLINE)
2020-03-14 17:40:52.096 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:5 (zone number 5 not paired)
2020-03-14 17:40:52.097 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:4 (zone number 4 not paired)
2020-03-14 17:40:52.098 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.098 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.098 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.098 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.099 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.098 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.099 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.099 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.099 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.100 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.101 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.101 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:2
2020-03-14 17:40:52.102 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.103 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.104 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.101 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.104 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.104 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.105 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.101 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.105 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.105 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.105 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.106 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.101 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.105 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.101 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:3
2020-03-14 17:40:52.103 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:2 (bridge ONLINE)
2020-03-14 17:40:52.107 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:2 (zone number 2 not paired)
2020-03-14 17:40:52.107 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:3 (bridge ONLINE)
2020-03-14 17:40:52.109 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:3 (zone number 3 not paired)
2020-03-14 17:40:52.113 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.113 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.112 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.114 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.115 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.119 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.120 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.120 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.119 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.120 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.122 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.122 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.123 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:40:52.123 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.124 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.125 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-14 17:40:52.125 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-14 17:40:52.126 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-14 17:40:52.126 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-14 17:40:52.126 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-14 17:41:12.093 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Powermax job...
2020-03-14 17:41:32.120 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Powermax job...
Lolodomo
(Lolodomo)
March 15, 2020, 9:11am
2
Was there any change in your setup?
It was previously working?
Try to restart the binding bundle.
Open and then exit from the panel setup to trigger a new download.
BigCol
(BigCol)
March 15, 2020, 11:14am
3
Lolodomo:
what do you mean by Open and then Exit please?
This was working fine, no issues for months.
Lolodomo
(Lolodomo)
March 15, 2020, 11:17am
4
I mean enter in your panel setup and then exit. In mine, this triggers a download.
BigCol
(BigCol)
March 15, 2020, 12:11pm
5
Download not triggered. i’ve restarted the binding, this is the output:
2020-03-15 12:09:19.784 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:4
2020-03-15 12:09:19.793 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:1
2020-03-15 12:09:19.802 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:2
2020-03-15 12:09:19.809 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:6
2020-03-15 12:09:19.817 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:5
2020-03-15 12:09:19.828 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:7
2020-03-15 12:09:19.836 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:8
2020-03-15 12:09:19.841 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:9
2020-03-15 12:09:19.848 [DEBUG] [nternal.handler.PowermaxThingHandler] - Handler disposed for thing powermax:zone:9d40033c:3
2020-03-15 12:09:19.855 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Handler disposed for thing powermax:serial:9d40033c
2020-03-15 12:09:19.856 [DEBUG] [al.connector.PowermaxSerialConnector] - close(): Closing Serial Connection
2020-03-15 12:09:19.864 [DEBUG] [internal.connector.PowermaxConnector] - cleanup(): cleaning up Connection
2020-03-15 12:09:20.039 [DEBUG] [ernal.connector.PowermaxReaderThread] - Data listener stopped
2020-03-15 12:09:20.039 [DEBUG] [internal.connector.PowermaxConnector] - cleanup(): Connection Cleanup
2020-03-15 12:09:20.157 [DEBUG] [al.connector.PowermaxSerialConnector] - close(): Serial Connection closed
2020-03-15 12:09:20.158 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - closeConnection(): disconnected
2020-03-15 12:09:20.954 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - initializing handler for thing powermax:serial:9d40033c
2020-03-15 12:09:30.956 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Powermax job...
2020-03-15 12:09:30.956 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - trying to reconnect...
2020-03-15 12:09:30.957 [DEBUG] [al.connector.PowermaxSerialConnector] - close(): Closing Serial Connection
2020-03-15 12:09:30.957 [DEBUG] [internal.connector.PowermaxConnector] - cleanup(): cleaning up Connection
2020-03-15 12:09:30.958 [DEBUG] [internal.connector.PowermaxConnector] - cleanup(): Connection Cleanup
2020-03-15 12:09:30.958 [DEBUG] [al.connector.PowermaxSerialConnector] - close(): Serial Connection closed
2020-03-15 12:09:30.958 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - closeConnection(): disconnected
2020-03-15 12:09:30.959 [DEBUG] [al.connector.PowermaxSerialConnector] - open(): Opening Serial Connection
2020-03-15 12:09:31.019 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - openConnection(): connected
2020-03-15 12:09:31.033 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:6
2020-03-15 12:09:31.019 [DEBUG] [internal.message.PowermaxCommManager] - sendMessage(): add message in queue (type DOWNLOAD)
2020-03-15 12:09:31.035 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:6 (bridge ONLINE)
2020-03-15 12:09:31.035 [DEBUG] [internal.message.PowermaxCommManager] - sendMessage(): sending DOWNLOAD message 0D2400004F48000000000000000A
2020-03-15 12:09:31.036 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:6 (zone number 6 not paired)
2020-03-15 12:09:31.038 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:9
2020-03-15 12:09:31.039 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:9 (bridge ONLINE)
2020-03-15 12:09:31.039 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:9 (zone number 9 not paired)
2020-03-15 12:09:31.038 [DEBUG] [ernal.connector.PowermaxReaderThread] - Data listener started
2020-03-15 12:09:31.040 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:7
2020-03-15 12:09:31.041 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:7 (bridge ONLINE)
2020-03-15 12:09:31.041 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:7 (zone number 7 not paired)
2020-03-15 12:09:31.044 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:1
2020-03-15 12:09:31.045 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:1 (bridge ONLINE)
2020-03-15 12:09:31.045 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:1 (zone number 1 not paired)
2020-03-15 12:09:31.048 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:8
2020-03-15 12:09:31.048 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:8 (bridge ONLINE)
2020-03-15 12:09:31.048 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:8 (zone number 8 not paired)
2020-03-15 12:09:31.050 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:4
2020-03-15 12:09:31.051 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:4 (bridge ONLINE)
2020-03-15 12:09:31.051 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:4 (zone number 4 not paired)
2020-03-15 12:09:31.051 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel system_status
2020-03-15 12:09:31.052 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel arm_mode
2020-03-15 12:09:31.052 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel system_armed
2020-03-15 12:09:31.052 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel alarm_active
2020-03-15 12:09:31.053 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:3
2020-03-15 12:09:31.053 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Received command REFRESH from channel trouble
2020-03-15 12:09:31.054 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:3 (bridge ONLINE)
2020-03-15 12:09:31.054 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:2
2020-03-15 12:09:31.055 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:2 (bridge ONLINE)
2020-03-15 12:09:31.055 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:2 (zone number 2 not paired)
2020-03-15 12:09:31.055 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.056 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.056 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.056 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.056 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.056 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.057 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.057 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.057 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.057 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.058 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.058 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.058 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.059 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.059 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.059 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.059 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.060 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.060 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.060 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.060 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.061 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.058 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.061 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.061 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.061 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.061 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.062 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.062 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.062 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.065 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.065 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.066 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.063 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.062 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.062 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.069 [DEBUG] [nternal.handler.PowermaxThingHandler] - Initializing handler for thing powermax:zone:9d40033c:5
2020-03-15 12:09:31.070 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel armed
2020-03-15 12:09:31.071 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel last_trip
2020-03-15 12:09:31.071 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel low_battery
2020-03-15 12:09:31.070 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel tripped
2020-03-15 12:09:31.071 [DEBUG] [nternal.handler.PowermaxThingHandler] - Received command REFRESH from channel bypassed
2020-03-15 12:09:31.071 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:3 (zone number 3 not paired)
2020-03-15 12:09:31.071 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to UNKNOWN for thing powermax:zone:9d40033c:5 (bridge ONLINE)
2020-03-15 12:09:31.073 [DEBUG] [nternal.handler.PowermaxThingHandler] - Set handler status to OFFLINE for thing powermax:zone:9d40033c:5 (zone number 5 not paired)
2020-03-15 12:09:51.041 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Powermax job...
2020-03-15 12:10:11.042 [DEBUG] [ternal.handler.PowermaxBridgeHandler] - Powermax job...
BigCol
(BigCol)
March 15, 2020, 12:12pm
6
Is there another way to trigger a download?
Or do I need to enroll Powerlink?
Lolodomo
(Lolodomo)
March 15, 2020, 1:59pm
7
Sorry I have no idea.
It looks like data is no more received.
Maybe check your connections.
BigCol
(BigCol)
March 15, 2020, 3:27pm
8
I’ve spun up a new instance of OH 2.5.2 and i’m having the same problem, so it’s not an OH issue. Myabe is the alarm panel, maybe it’s the cable - could be the server hardware but no likely.
BigCol
(BigCol)
March 15, 2020, 6:02pm
9
New console cable and all is good again…
