Hey.
I’m learning about rules and I am about to write a rule (as the title says), which is depending on presence and the sunset.
So i want the following to be done:
When I’m home, watching TV in the living room and the sun is down, i want the lights to get on.
To be more specific, having an eye on the rules:
When the sun is already down and i turn on my TV, which responds on a ping, then lights should be turned on.
Ok … Next step:
Channel ‘astro:sun:local:set#event’ triggered AND
Item LR_TV_ON changed
LR_lights_group.sendCommand(ON)
So far …
Item LR_TV_ON is liked to HTTP Binding, which pings my TV every 5 Minutes and waits 5 seconds for response. This is pretty much ok, i think, to get the stats of TV and so “know” whether I’m in the living room watching TV, while not “spamming” my LAN with ping requests.
BUT, I already see a problem here!
The rule only sends the command at exactly the point of time, when I’m watching TV AND the sunset begins. But what’s about when the sun is already down and I’m going to watch TV like an hour later? I tested … nothing happens!
Plz help me to get like a simply and working rule. Means, my first thoughts must not be the easiest way, but im stuck here …
