Does it allso work with android phones?
it has worked with iPhones, Pixel 2 XL and Pixel 3 XL.
Ok thanks, I will take a look at it tomorrow, its been a long day of programming and trying things out
Has anyone experimented with setting a 5 minute DHCP lease for mobile devices as a way to force a wake up? While it’s not super.high resolution, presumable it would be enough when coupled with a 10 minute timeout in the network binding to turn off lights/heating/music if nobody is at home.
Hi tried implementing [iPhone Presence Detection with hping3 and ARP]. I don’t get any errors but the script allways seems to return that my phone is present, even when it is switched off. Any ideas how i can further debug this?
this is the output in the log:
2018-12-27 09:33:00.164 [INFO ] [.eclipse.smarthome.model.script.RULE] - Iphone update
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
2018-12-27 09:33:00.176 [ome.event.ItemCommandEvent] - Item 'Iphone_Sw' received command ON
2018-12-27 09:33:00.210 [INFO ] [.eclipse.smarthome.model.script.RULE] - Iphone_Sw received command ON. Counter reset to 0
No idea where the admin lecture comes from either
Script:
#!/bin/bash
#Enter your ip of your device here
DEVICES="my device IP here"
for i in `echo $DEVICES`; do
# Change dev and eth0 if needed
ip neigh flush dev eth0 $i
hping3 -2 -c 10 -p 5353 -i u1 $i -q >/dev/null 2>&1
sleep 1
# Only arp specific device, grep for a mac-address
status=`arp -an $i | awk '{print $4}' | grep "..:..:..:..:..:.."`
statusMessage="OFF"
#A mac will be 17 characters including the ":"
if [ ${#status} -eq 17 ]; then
echo "Phone $i is detected!"
statusMessage="ON"
else
echo "Phone $i is not present"
statusMessage="OFF"
fi
done
The rule:
var Number IphoneCounter = 0
val Number MaxCounter = 18
rule "Execute script IphonePresence"
Time cron "0 * * * * ?"
var String IphoneExec = executeCommandLine("sudo@@bash@@/opt/IphoneD.sh", 5000)
Iphone.postUpdate(IphoneExec)
logInfo("RULE","Iphone update"+IphoneExec)
rule "Determine presence Iphone"
Item Iphone received update
then {
if(Iphone.state == "OFF") {
IphoneCounter = IphoneCounter + 1
if(IphoneCounter > MaxCounter) {
Iphone_Sw.sendCommand(OFF)
IphoneCounter = 0
logInfo("RULE","Iphone counter reached threshold and sent command OFF. Counter set to 0")
else {
logInfo("RULE","Counter Iphone threshold not yet reached. Counter set to " + IphoneCounter)
else {
Iphone_Sw.sendCommand(ON)
IphoneCounter = 0
logInfo("RULE","Iphone_Sw received command ON. Counter reset to 0")
ls -all looks like this:
-rwxrwxrwx 1 openhab root 624 Dec 27 08:55 IphoneD.sh
visudo last line (since i’m using openhabian):
openhabian ALL=(ALL) NOPASSWD: /bin/ip, /bin/bash
I do notice that where i inserted a logInfo in the first rule, that IphoneExec seems to be empty.
Sorry if i’m missing something stupid. Still got a lot to learn about linux
