Based on my previous post:
Now this part is solved, but I would like to improve a bit when the welcome message is performed, and when not.
The idea is to use a geofence system (I will use Location via IFTTT on my iPhone) and a couple of new items. When I will go away I’ll use the switch “Andrea_Presence_IFTTT” triggered by IFTTT, in order to be sure I’m 100% away, and not around the house for whatever reason. When that switch is changed to OFF, a new global switch “Andrea_Presence” is changed also to OFF. This is my rule:
// Presence (Away) IFTTT out
rule "Set Away"
Member of gPIFTTT changed to OFF
val setAway = gPIFTTT.members.filter[ a | a.state == OFF && a.name == triggeringItem.name].map[ name.replace("_Presence_IFTTT", "") ]
switch setAway {
case setAway.get(0) == "Andrea": sendCommand(Andrea_Presence, OFF)
case setAway.get(0) == "Cate": sendCommand(Cate_Presence, OFF)
I’m using a switch method because I will have more than 2 people involved.
The second part is more tricky and complicated for me. I would like to use my Unifi Binding as the wifi coverage is exactly mapping my house. The idea is: when someone comes to home, the wifi join will trigger the rule (switch “Andrea_Phone_Home_Unifi_online”) and IF the global switch “Andrea_Presence” is OFF (and not ON -> to avoid to receive a welcome message if I’m already at home but with my phone off) also a welcome message will be performed.
Let me resume the overall rule:
// Presence (Home) Unifi in
rule "Welcome home my dear"
Member of gPhones changed to ON
if(cameHomeTimer !== null) {
return; // do nothing if there is already a Timer
//logInfo("test", "Rule triggered by " + triggeringItem.name + " at " + now.toString)
cameHomeTimer = createTimer(now.plusSeconds(5), [ |
val cameHome = gPhones.members.filter[ p | p.state == ON && (p.name == triggeringItem.name || (p.lastUpdate !== null && p.lastUpdate.isAfter(now.minusSeconds(6)))) ].map[ name.replace("_Phone_Home_Unifi_online", "") ]
//gPhones.members.forEach[ p | logInfo("test", "Values for " + p.name + "\n" + "State = " + p.state.toString + "\n" + "LastUpdate = " + p.lastUpdate.toString)]
var message = "Benvenuti a casa, "
switch(cameHome.size) {
case 0: {
logError("came home", "Unexpected number of phones: " + cameHome.size)
return;
case cameHome.size == 1 && cameHome.get(0) == "Andrea": message = "Benvenuto a casa, Andrea"
case cameHome.size == 1 && cameHome.get(0) == "Cate": message = "Benvenuta a casa, Caterina"
case cameHome.size == 1 && cameHome.get(0) == "Sofia": message = "Benvenuta a casa, Sofia"
case cameHome.size == 1 && cameHome.get(0) == "Edo": message = "Benvenuto a casa, Edoardo"
default: {
message = message + cameHome.members.reduce[ String list, String name | list + ", " + name ]
val ind = message.lastIndexOf(",")
message = new StringBuilder(str).replace(ind, ind+1," e").toString();
//logInfo("check message", "message is: " + message)
Echo_Living_Room_TTS_Volume.sendCommand('90')
Echo_Living_Room_TTS.sendCommand('<speak><break time="2s"/>' + message + '</speak>')
cameHomeTimer = null
The problem is at the end. I need to find a way to say (like val cameHome):
- if cameHome is eg. Andrea, and the item “‘cameHome’_Presence” is OFF, play the message and set at the end the item “‘cameHome’_Presence” to ON
- the same with other people
- if there are more than 1 coming in, do the same with all names in the list
Any suggestion?
Andrea
