Hi there,
i want to configure a presence detection with iCloud-Binding with two iPhones. I already installed the Binding and the bridge is online and working.
The first iPhone, my device is working fine. But I get no connection with the device of my wife. I have the family-sharing activated. The sharing works fine.
Here are my items:
//iPhone A
Group giPhone_A "iPhone A" <iphone> (gAnwesenheit)
Number iPhone_BatteryLevel_A "Batterie [%d %%]" <battery> {channel="icloud:device:7d938589:82ce4474:batteryLevel"}
DateTime iPhone_LocationLastUpdate_A "letzer Empfang [%1$td.%1$tm.%1$tY, %1$tH:%1$tM]" <time> {channel="icloud:device:7d938589:82ce4474:locationLastUpdate"}
Switch iPhone_Home_A "Zuhause" <presence>
Switch iPhone_Refresh_A "Koordinaten auffrischen" {channel="icloud:device:7d938589:82ce4474:location", autoupdate="false"}
Location iPhone_Location_A "Koordinaten" <gps> {channel="icloud:device:7d938589:82ce4474:location"}
//iPhone K
Group giPhone_K "iPhone K" <iphone> (gAnwesenheit)
Number iPhone_BatteryLevel_K "Batterie [%d %%]" <battery> {channel="icloud:device:7d938589:4ff33ce:batteryLevel"}
DateTime iPhone_LocationLastUpdate_K "letzer Empfang [%1$td.%1$tm.%1$tY, %1$tH:%1$tM]" <time> {channel="icloud:device:7d938589:4ff33ce:locationLastUpdate"}
Switch iPhone_Home_K "Zuhause" <presence>
Switch iPhone_Refresh_K "Koordinaten auffrischen" {channel="icloud:device:7d938589:4ff33ce:location", autoupdate="false"}
Location iPhone_Location_K "Koordinaten" <gps> {channel="icloud:device:7d938589:4ff33ce:location"}
Sitemap:
Group item=giPhone_A {
Text item=iPhone_BatteryLevel_A
Switch item=iPhone_Home_A mappings=[ON=âanwesendâ, OFF=âabwesendâ]
Text item=iPhone_LocationLastUpdate_A
Switch item=iPhone_Refresh_A mappings=[REFRESH=âjetzt aktualisierenâ]
Mapview item=iPhone_Location_A height=10
Group item=giPhone_K {
Text item=iPhone_BatteryLevel_K
Switch item=iPhone_Home_K mappings=[ON="anwesend", OFF="abwesend"]
Text item=iPhone_LocationLastUpdate_K
Switch item=iPhone_Refresh_K mappings=[REFRESH='jetzt aktualisieren']
Mapview item=iPhone_Location_K height=10
Rules:
rule âiPhone Home Aâ
Item iPhone_Location_A changed
// specify your home location
val PointType home_location = new PointType(new DecimalType(50.12), new DecimalType(8.45))
val PointType phone_location = iPhone_Location_A.state as PointType
val int distance = phone_location.distanceFrom(home_location).intValue()
// specify your preferred radius (in meters)
if ( distance < 200) {
iPhone_Home_A.postUpdate(ON)
logInfo(âiPhone Homeâ, âiPhone is at home.â)
} else {
iPhone_Home_A.postUpdate(OFF)
logInfo(âiPhone Homeâ, âiPhone is away.â)
rule "iPhone Home K"
Item iPhone_Location_K changed
val PointType phone_location = iPhone_Location_K.state as PointType
iPhone_Home_K.postUpdate(ON)
logInfo("iPhone K Home", "iPhone K is at home.")
} else {
iPhone_Home_K.postUpdate(OFF)
logInfo("iPhone K Home", "iPhone K is away.")
Has somebody an idea whatâs wrong?
Thank you guys!
Kind regards,
