I tried to manage the Presence with MQTT. The connection to MQTT works fine and the Item “position_stajon_raw” is filled like this:
"link": "http://172.16.0.1:8080/rest/items/position_stajon_raw",
"state": "{\"cog\":170,\"batt\":30,\"lon\":8.xxxxx,\"acc\":16,\"p\":98.83165740966797,\"vel\":36,\"vac\":3,\"lat\":49.xxxxx,\"t\":\"c\",\"conn\":\"m\",\"tst\":1488211089,\"alt\":119,\"_type\":\"location\",\"tid\":\"AN\"}",
"type": "String",
"name": "position_stajon_raw",
"label": "Rohdaten: Jonathan",
"tags": [],
"groupNames": []
Now I tried to use this rule:
rule "postion_parse_stajon"
Item position_stajon_raw changed or
Item position_stajon_raw received update
val String json = (position_stajon_raw.state as StringType).toString
val String type = transform("JSONPATH", "$._type", json)
if (type == "location") {
val String lat = transform("JSONPATH", "$.lat", json)
val String lon = transform("JSONPATH", "$.lon", json)
val String acc = transform("JSONPATH", "$.acc", json)
val String batt = transform("JSONPATH", "$.batt", json)
position_stajon_latitude.postUpdate(lat)
position_stajon_longitude.postUpdate(lon)
location_stajon.postUpdate(new PointType(lat + "," + lon))
position_stajon_accuracy.postUpdate(new DecimalType(acc))
position_stajon_battery.postUpdate(new PercentType(batt))
But the Items still empty
Anyone with an idea
