Thank you Michael, I have updated as you have indicated and I can now see and control my tradfri lights and plugs devices without the Ikea Gateway
I have however noticed three small issues:
When I have set the pulling time to 10 sec for the Alexa connected devices I have got the following error message but the pulling time has correctly been updated:
14:37:12.797 [ERROR] [ntrol.internal.handler.AccountHandler] - check login fails with unexpected error {}
at java.net.URLEncoder.encode(Unknown Source) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.exchangeToken(Connection.java:768) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.checkRenewSession(Connection.java:820) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.tryRestoreSessionData(Connection.java:414) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.tryRestoreLogin(Connection.java:335) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.checkLogin(AccountHandler.java:386) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
I have noticed that when I reopen the Control screen on PaperUI the device state is not updated
I have also noticed that following a PaperUI action the log is going through some unexpected states but eventually gets the correct state. For example when I set a light to ON on PaperUI I have the following log states:
15:07:09.585 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'amazonechocontrol_smartHomeDeviceGroup_e5e78250_amzn1_HomeAutomation_ApplianceGroup_A3JG2AXOV5CMGL_3a2d692d_e53b_4cf1_882d_ff15530d5096_powerState' received command ON
15:07:09.586 [INFO ] [arthome.event.ItemStatePredictedEvent] - amazonechocontrol_smartHomeDeviceGroup_e5e78250_amzn1_HomeAutomation_ApplianceGroup_A3JG2AXOV5CMGL_3a2d692d_e53b_4cf1_882d_ff15530d5096_powerState predicted to become ON
15:07:09.588 [INFO ] [smarthome.event.ItemStateChangedEvent] - amazonechocontrol_smartHomeDeviceGroup_e5e78250_amzn1_HomeAutomation_ApplianceGroup_A3JG2AXOV5CMGL_3a2d692d_e53b_4cf1_882d_ff15530d5096_powerState changed from OFF to ON
15:07:11.338 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:smartHomeDeviceGroup:e5e78250:amzn1-HomeAutomation-ApplianceGroup-A3JG2AXOV5CMGL-3a2d692d-e53b-4cf1-882d-ff15530d5096' changed from ONLINE to UNKNOWN
15:07:11.341 [INFO ] [smarthome.event.ItemStateChangedEvent] - amazonechocontrol_smartHomeDeviceGroup_e5e78250_amzn1_HomeAutomation_ApplianceGroup_A3JG2AXOV5CMGL_3a2d692d_e53b_4cf1_882d_ff15530d5096_powerState changed from ON to OFF
15:07:20.687 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:smartHomeDeviceGroup:e5e78250:amzn1-HomeAutomation-ApplianceGroup-A3JG2AXOV5CMGL-3a2d692d-e53b-4cf1-882d-ff15530d5096' changed from UNKNOWN to ONLINE
15:07:20.687 [INFO ] [smarthome.event.ItemStateChangedEvent] - amazonechocontrol_smartHomeDeviceGroup_e5e78250_amzn1_HomeAutomation_ApplianceGroup_A3JG2AXOV5CMGL_3a2d692d_e53b_4cf1_882d_ff15530d5096_powerState changed from OFF to ON
Please do not do this, or make it configurable. The announcements are not specific to an Amazon account, and they go to all devices in an Amazon āhouseholdā. For example, we have 3 families in our household. You can guess what happened when I played with announcements at 2am when they first came out!
Iāve actually made queue for multiple messages almost the same way. Expire binding item with 5 seconds timer - while the timer (switch) is ON, Iām adding text to a string item and extending timer. If no message is received in 5 seconds switch goes to OFF, sends text to Echo TTS item, and resets string item to an empty string. But, as Iāve already said, it creates slight delay and is a bit annoying. Anyway, thank you for the explanation.
As far as I see, there are two types of Announcments. One type is send to the account and starts the green light, but the other one which can be found in the alexa routines have a specific device id and only speaks a message (and shows a short popup).
Both functions can be tested with current binding. The announcement channel (which I want use for the TTS implemention) can be found in the echo things, the other one is named sendMessage which makes the global announcment with the green light.
When I trigger Alexa and ask her to play from Spotify, the channel āplayerā correctly switches from PAUSE to PLAY. And when I stop the song, it switches correctly back from PLAY to PAUSE.
Once I start to trigger a radio channel (play bla bla from tunein), the channel āplayerā currently does nothing. No value is given back at this stage, not triggering any of my rules (obviously).
Any Idea on what happened? I am almost certain it was working recently. Using the current 2.5 RC release advertised on top.
Just try to create an echo Thing for your Fire TV Cube. You will get the required id from the web page of the binding. After this, you can test which channels are working. If you can provide me a full list, I would be able to create an own thing type for this.
Thanks for this new addon, its great for some devices, especially skill ones that have difficult openhab direct integration ( yeelight is so much better ā¦ ) I was wondering if there is a plan to support sensors
I have some amazon integrated wifi door and motion sensors and it could be much easier to run those thru the alexa instead of direct to openhab.
