Hello, I’m running openhab 1.8.1 on a raspberry pi. Everything was running well for a few weeks, I ran an update and rebooted and now can’t access the openhab webapp from my laptop or through my.openhab. I get this error
HTTP ERROR 404
Problem accessing /openhab.app. Reason:
ProxyServlet: /openhab.app
Powered by Jetty://
Do you have any unexpected files lingering in your addons directory? Did you make any permissions changes before the reboot? Did you run openHAB as root and then later as a normal user? Definitely an odd one…
I had that behavior with a clean install of 1.8.1 (using apt-get). The Runtime was generally working, Rules would execute etc, but the UI components would return the error you’ve listed.
Looking at the OSGi Console showed a few unresolved dependencies. I don’t recall what they are now, but they were fairly obvious (a few services not in Active state in the OSGi ls output)
For my case, I did a force-reinstall of openhab-runtime, using the --reinstall option, and it all came back to life:
sudo apt-get install openhab-runtime --reinstall
Since it’s a shot-in-the-dark, make a Backup before going this route.
Thanks!, a --purge and then reinstalling openhab-runtime is what finally
got things working again. My zwave isn’t working because I think I missed
something when backing up, but I can figure that out.
