Using Raspberry Pi and Aeon Gen5 z-stick, OH2. First device was a GE zwave in-wall light switch which works perfectly. 2nd device is a zwave appliance module. I’m able to get the z-stick to see it and HABmin lists it as a “Thing”, but after configuring it, (so now I have 2 switches defined) regardless of which switch I click on, both devices turn on/off. I can’t get it to see the 2nd device as a separate thing. What am I doing wrong? Thanks in advance for any help! Long term goal is to replace Smartthings, but starting off slowly!
-Jeff
Post your Item definitions.
Also, some devices, switches in particular, have Scenes that allow the switch to control other zwave devices without going through the controller. Perhaps that is happening. Without more information it is impossible to say.
I’ve been using HABmin, so I don’t have *.item files. How do I dump the definitions?
Also, here is a snippet of an apt-get update:
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,856 kB in 32s (301 kB/s)
W: Failed to fetch https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-offline/target/apt-repo/Packages HttpError404
W: Failed to fetch https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-online/target/apt-repo/Packages HttpError404
E: Some index files failed to download. They have been ignored, or old ones used instead.
Assuming this may be related to the problems I’m, experiencing. Any idea why I’m getting these errors?
It is a problem but highly unlikely to be related.
Please see the Installation Insructions and make sure that you are using the correct repos. They recently had to move the snapshot distros to a different location as Cloudbees doesn’t allow them to host them there.
Make sure that your Items are not linked to the same channel. That is the end of my suggestions. I’m no zwave expert.
