First, OK - removed the OH1 things and my item files now states:
Number Scene_KitchenTable "köket scen" { channel="zwave:device:bdd1ce45:node9:scene_number" }
However - I still only see:
22:47:53.574 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
22:47:53.575 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
22:47:53.577 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@722e84 already registered
22:47:53.578 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SCENE_ACTIVATION
22:47:53.580 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - Received Scene Activation for Node ID = 9
22:47:53.581 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - Scene Activation Set
22:47:53.583 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - Scene activation node from node 9: Scene 26, Time 255
22:47:53.584 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
22:47:53.586 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
22:47:53.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SCENE_ACTIVATION, value = 26
One thing I realize - I misstok the device type from a newer dimmer I have installed. This unit is FGD-211 and not FGD-212. The “scene_number” channel is not presented in the UI (Paper UI or HABmin). Could that be a problem?
Can you post the XML file that OH generates for this device?
The database is auto generated from an SQL backend, so we just add the data into the system (but yes, it should create something very similar if not the same as this ).
When do you think you will have the possibility to add this? No stress ;)!
To update (after the change) - do I only need to remove and att the zwave binding from the extension list in OH2 PaperUI? I am using the online version of OH2.
After updating OH2 to latest snapshot and solving a couple of issues - I removed my Thing for the FGD211 unit and then discovered it again. Now the channel is present and I get the scene number correct.
