Yes, it was installed. But timestamps looked suspicious (date was different
than for other files), so I reinstalled corresponding package, updated my
system and it’s alright now, serial is working. Thanks for helping me to
figure it out!
I’m not sure, but it is possible that I made a mistake during installation.
It appears that serial needs both binding and io packages to be installed,
binding seem to be dependent on io. It is possible that I first installed
just io, binding later and they didn’t match somehow.
Btw, is OSGI console documented somewhere? Seem like a helpful tool.
smar https://community.openhab.org/users/smar -
February 5
Did you exit telnet with CTRL-C? If so, that would have killed your
openhab session as well.
I don’t have 1.8.1 installed yet, but looking at its addons bundle, I see
org.openhab.binding.serial-1.8.1.jar. Do you have this installed in your
addons folder? If so, could it be corrupt?
Previous Replies
jtupulis https://community.openhab.org/users/jtupulis Janis Tupulis
February 5
Thanks for giving the short intro, sometimes you can’t find this kind of
advice searcing for hours on yourself [image:
Actually, serial is not even on the list for me, no org.openhab.io.serial
there. openhab-addon-io-serial package is installed.
Plus, after exiting OSGI console, I can’t connect to it anymore: telnet:
Unable to connect to remote host: Connection refused
On Fri, Feb 5, 2016 at 9:34 PM - bot@community.openhab.org
https://community.openhab.org/users/smar February 5
To access the OSGI console, first you need to check that your openhab
startup includes the argument:
-console=5555
You then telnet onto the openhab server at that port. If for example, you
are in a shell on the openhab server itself, you’d enter:
telnet localhost 5555
If all is well, you will get an osgi> prompt. Basic commands for the osgi
console are given here:
https://github.com/openhab/openhab/wiki/Commands-for-the-OSGi-console
If you use the ss command, you’ll get a list of all the installed bundles
and their status. Running that just now on mine, I see the serial binding
line as follows:
222 ACTIVE org.openhab.binding.serial_1.7.1
This tells me that my serial binding (with ID 222) is active and working
correctly.
Previous Replies jtupulis https://community.openhab.org/users/jtupulis
Janis Tupulis https://community.openhab.org/users/jtupulis February 4
No, I haven’t had an opportunity to use/learn OSGI console yet. I think I
understand the concept, but I don’t see a topic in openhab wiki about OSGI
console, must be a java environment thing, right? From the other hand, I
can see that openhab has installed
/usr/share/openhab/server/plugins/org.eclipse.osgi_3.8.2.v20130124-134944.jar
Do I run that jar in console mode? Generally speaking, where/how do I start
with it for practical purposes?
On Wed, Feb 3, 2016 at 12:25 PM - bot@community.openhab.org
https://community.openhab.org/users/smar February 3
Sorry, not a lot else to suggest then. I assume you’ve confirmed that the
serial binding is properly loaded (via OSGI console)?
Janis Tupulis https://community.openhab.org/users/jtupulis February 2
Yes, openhab user added to dialout group. Port name is correct and
working, as I mentioned, I can test it with other tools outside openhab.
On Mon, 1 Feb 2016 at 11:24 - bot@community.openhab.org
https://community.openhab.org/users/smar February 1
I assume your openhab user has the appropriate permissions? i.e. it has
been added to the dialout group?
If you have, I can’t really think of anything else, assuming you are sure
that port name is correct (I’m also running on ubuntu, and the port changes
when the USB is unplugged/plugged etc, and so the use of symlinks).
Janis Tupulis https://community.openhab.org/users/jtupulis January 31
Thanks for your questions/suggestions.
Yes, thats what I ment.
[%s] is output formatting when displaying the string, I have difficulty
having the string.
57600 speed was working for me previously. But I tried 115200 too with no
avail. jtupulis https://community.openhab.org/users/jtupulis Janis
Switched to debug logging, restarted openhab. Nothing regarding serial in
the log…
Visit Topic
Problem getting serial to work after 1.7 -> 1.8 migration
or reply to this email to respond.
To stop receiving notifications for this particular topic, click here
https://community.openhab.org/t/problem-getting-serial-to-work-after-1-7-1-8-migration/6968/unsubscribe.
To unsubscribe from these emails, change your user preferences
https://community.openhab.org/my/preferences
– Veiksmi, Jānis
Visit Topic
Veiksmi, Jānis jtupulis https://community.openhab.org/users/jtupulis
I did clean install of Ubuntu. Installed openhab-runtime and all other
openhab* packages listed on the old system. Did main config file changes
manually, just ntp and milight binding config there, both working. Copied
items, sitemap, rules and some other config files from configurations
directory. Copied some icons. Copied mapdb and rrd4j data files. Not that I
remember every single detail, but I hope you can understand the approach.
On Mon, 1 Feb 2016 at 21:59 Dirk Clemens bot@community.openhab.org
dirkc https://community.openhab.org/users/dirkc Dirk Clemens
https://community.openhab.org/users/dirkc February 1
I had problems upgrading to 1.8.0 Can you please explain what you did when
upgrading? I tried it once and changed only /server and /addons and
/workspace folders with the new files but I was facing problems with this
approach.
Visit Topic
Veiksmi, Jānis
Visit Topic
Veiksmi, Jānis
Visit Topic
https://community.openhab.org/t/problem-getting-serial-to-work-after-1-7-1-8-migration/6968/16
