System: Openhab 2.1
I am trying to install Google Calendar Presence Simulator binding but after clicking on ‘Install’ button on ‘Google Calendar Presence Simulator’ under Paper UI --> Add ons --> Persistence, I am getting the following on the log viewer:
2017-10-08 13:55:19.703 [WARN ] [gcal.internal.GCalPersistenceService] - gcal-persistence:calendar_name must be configured in openhab.cfg. Calendar name or word "primary" MUST be specified
2017-10-08 13:55:19.769 [ExtensionEvent ] - Extension 'persistence-gcal' has been installed.
2017-10-08 13:55:20.147 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed uninstalling 'openhab-misc-gcal1': Feature named 'openhab-misc-gcal1/0.0.0' is not installed
However, two config files are created in
’\OPENHABIANPI\openHAB-conf\services’,
the gcal-persistence.cfg and gcal.cfg
I entered the needed information in the above two files
(calendar_name in gcal-persistence.cfg
and client_id, client_secret and calendar_name in gcal.cfg)
I also created gcal.persist that contains:
Strategies {
default = everyChange
}Items {
gPerSim* : strategy = everyChange
The log shows:
2017-10-08 14:06:24.230 [INFO ] [b.core.service.AbstractActiveService] - Google Calendar Event Downloader has been started
2017-10-08 14:06:42.427 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'gcal.persist' has errors, therefore ignoring it: [1,1]: mismatched input '<EOF>' expecting 'Strategies'
2017-10-08 14:06:42.455 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'gcal.persist'
After that I restarted Openhab, the log shows:
2017-10-08 14:14:16.516 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled ‘openhab-persistence-gcal’
2017-10-08 14:14:16.520 [ExtensionEvent ] - Extension ‘persistence-gcal’ has been uninstalled.
Also the Paper UI shows that Google Calendar Presence Simulator is UN-installed
Any idea about what goes wrong here?
