If you get the same error but the Require-Bundle instruction is not in your new JAR, then you might still be running the old bundle. At the openhab> prompt, bundle:list and bundle:uninstall <id> the old one.
Finally I was able to compile it without the “require” line and now it load in OH2.
By the way, someone should check the wiki page regarding setting-up eclipse to develop OH2 plugins because the instructions given there don’t work. (you end up with more than 200 error in compilation!) . I’ve needed the help of a friend who knows very well eclipse to set it up.
regarding mpower binding, now it works. I’ve created an mpower.cfg file in services to define une plug and I can see in log:display that the binding starts and connectes to the plug, but in paper UI the binding doesn’t show up, an there is no “thing” representing this plug?
