Good day everyone.
This is my first post, so I want to thank everyone in here for the great job and gigantic help they gave me with their threads.
I have a Openhab installation configured like this:
- Platform information:
- Hardware: Raspberry Pi 3
- OS: Xbian 4.9.78
- Java Runtime Environment: Zulu Embedded 8.25.0.76-linux-aarch32hf
- openHAB version: openHAB 2.2.0 Release Build
Last week, due to a lighting storm, my RPi3 stopped working, and had to reinstall everything again. Luckily I had a backup of my last configuration, and used restore script to reset things up. Everything is working fine except MQTT Binding. Searching forum for some similar cases I found that MQTT-action was causing MQTT Binding misfunction. So i decided to give it a try, but when I click on Uninstall button on PaperUI next to MQTT action, the “work in progress” icon start spinning but nothing happens.
I then tried to uninstall it from Console, and things seemed to have worked well as if I go with a bundle:list command MQTT Action is not showing anymore. Problem is that I continue to see it in PaperUI and nothing has changed from this side.
Is there a way to syncronize things (if this is the problem?)
Thanks to everyone willing to point me in the right direction.
