- Platform information:
- Hardware: Synology DS918+
- OS: DSM 6.2.1-23824
- Java Runtime Environment: Java 8.0.161-0015
- openHAB version:2.3.0.005
- Issue of the topic:
Hello Ladies and Gentlemen,
got a few issues getting my HMIP-WCR2 running to switch via openHAB rule a HMIP-FSM.
This worked for weeks, after a reboot I had the issues. I tried to reinstall the system, but the same happens.
Got a binding on my Homematic CCU2.
I have two Things, the HMIP-WCR2 and the HMIP-FSM. I have tried different ways.
Using change to ON on the PRESS_SHORT parameter and using the triggered SHORT on the PRESS parameter.
However I can see the parameter switching in the logfile and on the sitemap.
I am also able to switch the HMIP-FSM through HM and OpenHAB.
- Please post configurations (if applicable):
Switch 00WohnzimmerLichtschalter01_1_PressShort "Test 1" <power> { channel="homematic:HMIP-WRC2:MEQ1609961:000193C99519F8:1#PRESS_SHORT" }
Switch 00WohnzimmerLichtschalter01_2_PressShort "Test 2" <power> { channel="homematic:HMIP-WRC2:MEQ1609961:000193C99519F8:2#PRESS_SHORT" }
Switch 00WohnzimmerLichtschalter01_1_Press "Test 3" <power> { channel="homematic:HMIP-WRC2:MEQ1609961:000193C99519F8:1#PRESS" }
Switch 00WohnzimmerLichtschalter01_2_Press "Test 4" <power> { channel="homematic:HMIP-WRC2:MEQ1609961:000193C99519F8:2#PRESS" }
Switch EGGartenLaterne_2_State "Licht Garten" <light> { channel="homematic:HmIP-FSM:MEQ1609961:000898A994E151:2#STATE" }
The Rules I tried…
val String filename = "fuksbau.rules"
rule "EG Garten Laterne Ein/Aus"
Item 00WohnzimmerLichtschalter01_1_PressShort changed to ON or Item 00WohnzimmerLichtschalter01_2_PressShort changed to ON
if (EGGartenLaterne_2_State.state == OFF) {
EGGartenLaterne_2_State.sendCommand(ON)
} else {
EGGartenLaterne_2_State.sendCommand(OFF)
and:
Item 00WohnzimmerLichtschalter01_1_Press triggered SHORT or Item 00WohnzimmerLichtschalter01_2_Press triggered SHORT
} else {
Any ideas?
