Problem voicerss
Hi
I have a problem with my voicerss I get this error
2019-04-29 11:57:34.501 [ERROR] [nal.cloudapi.CachedVoiceRSSCloudImpl] - Could not write /var/lib/openhab2/voicerss/cache/da-DK_896618a00e91c4569f635a220f09193e.mp3 to cache
java.io.IOException: Could not read audio content, service return an error: ERROR: The API key is not av
at org.openhab.voice.voicerss.internal.cloudapi.VoiceRSSCloudImpl.getTextToSpeech(VoiceRSSCloudImpl.java:149) ~[?:?]
at org.openhab.voice.voicerss.internal.cloudapi.CachedVoiceRSSCloudImpl.getTextToSpeechAsFile(CachedVoiceRSSCloudImpl.java:64) ~[?:?]
at org.openhab.voice.voicerss.internal.VoiceRSSTTSService.synthesize(VoiceRSSTTSService.java:136) ~[?:?]
at org.eclipse.smarthome.core.voice.internal.VoiceManagerImpl.say(VoiceManagerImpl.java:213) ~[?:?]
at org.eclipse.smarthome.model.script.actions.Voice.say(Voice.java:121) ~[?:?]
at org.eclipse.smarthome.model.script.actions.Voice.say(Voice.java:40) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:341) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-04-29 11:57:34.527 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying ‘Det ringer på. Luk venligst op’: Could not read from VoiceRSS service
org.eclipse.smarthome.core.voice.TTSException: Could not read from VoiceRSS service
at org.openhab.voice.voicerss.internal.VoiceRSSTTSService.synthesize(VoiceRSSTTSService.java:139) ~[?:?]
2019-04-29 11:57:34.624 [ERROR] [nal.cloudapi.CachedVoiceRSSCloudImpl] - Could not write /var/lib/openhab2/voicerss/cache/da-DK_896618a00e91c4569f635a220f09193e.mp3 to cache
at org.eclipse.smarthome.model.script.actions.Voice.say(Voice.java:102) ~[?:?]
2019-04-29 11:57:34.645 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying ‘Det ringer på. Luk venligst op’: Could not read from VoiceRSS service
My guess the truncatedc word should be “available”. I suggest you check your API on the voicerss Webpage. I had an instance (read here) when my key didn’t work, which was caused by works on their server. Mailed the problem to them and the key was working again after a day or so.
17/5000
thanks, it worked
