You’ve used the rule name twice. Every name (rule, item, val and var defined outside a rule) must be unique.
Please be aware that the time cron string is more common if setting the ? to the dayOfWeek part, though your diction should also work:
Time cron "0 1 22 * * ?" //every day @ 22:01:00, do not care about day of week or year
Time cron "0 30 7 * * ?" //every day @ 07:30:00, do not care about day of week or year
You should always prefer the method over the action:
