I have generate a notification for forgotten open window and send TTS commands to all my Echo devices
it is working fine for one device, but if i put all of them i generates errors and it doesn’t work
your code goes here2019-01-26 17:17:06.653 [ome.event.ItemCommandEvent] - Item 'Echo_Emelie_Volume' received command 60
2019-01-26 17:17:06.670 [nt.ItemStatePredictedEvent] - Echo_Emelie_Volume predicted to become 60
2019-01-26 17:17:06.685 [ome.event.ItemCommandEvent] - Item 'Echo_Kueche_Volume' received command 60
2019-01-26 17:17:06.689 [ome.event.ItemCommandEvent] - Item 'Echo_Bad_Volume' received command 60
2019-01-26 17:17:06.694 [vent.ItemStateChangedEvent] - Echo_Emelie_Volume changed from 27 to 60
2019-01-26 17:17:06.697 [ome.event.ItemCommandEvent] - Item 'Echo_Garten_TTS_Volume' received command 60
2019-01-26 17:17:06.703 [ome.event.ItemCommandEvent] - Item 'Echo_Emelie_TTS' received command Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.705 [ome.event.ItemCommandEvent] - Item 'Echo_Kueche_TTS' received command Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.707 [nt.ItemStatePredictedEvent] - Echo_Kueche_Volume predicted to become 60
2019-01-26 17:17:06.710 [ome.event.ItemCommandEvent] - Item 'Echo_Bad_TTS' received command Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.714 [ome.event.ItemCommandEvent] - Item 'Echo_Garten_TTS' received command Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.716 [nt.ItemStatePredictedEvent] - Echo_Bad_Volume predicted to become 60
2019-01-26 17:17:06.719 [vent.ItemStateChangedEvent] - Echo_Kueche_Volume changed from 20 to 60
2019-01-26 17:17:06.721 [nt.ItemStatePredictedEvent] - Echo_Garten_TTS_Volume predicted to become NULL
2019-01-26 17:17:06.738 [nt.ItemStatePredictedEvent] - Echo_Emelie_TTS predicted to become Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.745 [nt.ItemStatePredictedEvent] - Echo_Kueche_TTS predicted to become Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.748 [vent.ItemStateChangedEvent] - Echo_Bad_Volume changed from 25 to 60
2019-01-26 17:17:06.751 [nt.ItemStatePredictedEvent] - Echo_Bad_TTS predicted to become Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.754 [vent.ItemStateChangedEvent] - Echo_Emelie_TTS changed from to Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.756 [vent.ItemStateChangedEvent] - Echo_Kueche_TTS changed from to Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.758 [nt.ItemStatePredictedEvent] - Echo_Garten_TTS predicted to become Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.761 [vent.ItemStateChangedEvent] - Echo_Bad_TTS changed from to Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
2019-01-26 17:17:06.763 [vent.ItemStateChangedEvent] - Echo_Garten_TTS changed from to Sehr geehrte Bewohner, das Badezimmer Fenster ist noch offen bitte umgehend, schliessen , danke
and here the Error
2019-01-26 17:17:07.481 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@177f55c': POST url 'https://alexa.amazon.de/api/behaviors/preview' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.de/api/behaviors/preview' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:549) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceNode(Connection.java:1067) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceCommand(Connection.java:1052) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.textToSpeech(Connection.java:1043) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.startTextToSpeech(EchoHandler.java:640) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:527) ~[?:?]
at sun.reflect.GeneratedMethodAccessor98.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy153.handleCommand(Unknown Source) [229:org.openhab.binding.amazonechocontrol:2.4.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor97.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
2019-01-26 17:17:07.500 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@149717d': POST url 'https://alexa.amazon.de/api/behaviors/preview' failed: Bad Request
2019-01-26 17:17:07.489 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@756fb6': POST url 'https://alexa.amazon.de/api/behaviors/preview' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceNodes(Connection.java:1076) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.textToSpeech(Connection.java:1038) ~[?:?]
any idea ?
thanks
Thomas
