Problem with Astro items - Azimut
Hi there,
I made a short rule but I do not know what I am doing wrong. I also did not find any solution in this Community.
Please help me!
I want to shut my roller shutters in the summer when the sun comes around the house down and want to run them automatically again up.
Before this I want just to send an email to check the times. Later I will replace this section.
Here is my code:
rule "Rollladen EG halb runter und wieder hoch"
   Item Lokale_Sonnendaten_Azimut received update
   if(UrlaubRollladenHochRunter.state == ON){
         if((VarHochRunterNachmittags.state as Number == 0) && ((Lokale_Sonnendaten_Azimut.state as Number) > 95) && ((Lokale_Sonnendaten_Azimut.state as Number) < 100)){
            //Roller Shutter half way down
            VarHochRunterNachmittags.sendCommand(1)
            val mailActions = getActions("mail","mail:smtp:bergserversmtp")
            mailActions.sendMail("chris@...com", "Rollladen geht runter auf 18", "Rollladen geht runter auf 18")
           EGRollladenSuedrechts.sendCommand(18)
         }else if((VarHochRunterNachmittags.state as Number == 1) && ((Lokale_Sonnendaten_Azimut.state as Number) > 200) && ((Lokale_Sonnendaten_Azimut.state as Number) < 205)){
            //Roller Shutter up again
            VarHochRunterNachmittags.sendCommand(0)
            mailActions.sendMail("chris@...com", "Rollladen geht wieder auf", "Rollladen geht wieder auf")
           EGRollladenSuedrechts.sendCommand(100)
Logs?
You are checking (Lokale_Sonnendaten_Azimut.state as Number) but it’s most likely that the Item is of Type Number:Angle, so at least you would have to use (Lokale_Sonnendaten_Azimut.state as Number).floatValue to ensure there is no unit.
A working comparison with Number:Angle is, e.g.:
if ( v_sun_az.state > 160.0 | "°" ) then { ... }
Maybe consider to use a more clear approach:
    Item Lokale_Sonnendaten_Azimut changed                                      // will be sufficient
    if(UrlaubRollladenHochRunter.state != ON)                                   // rule not active?
        return;
    if(!(newState instanceof Number))                                           // Itemstate not valid?
        return;
    val mailActions = getActions("mail","mail:smtp:bergserversmtp")             // get handle for message
    val nAzimut = (newState as Number).floatValue                               // get Float Value (i.e. without °)
    if(nAzimut > 95 && nAzimut < 100 && VarHochRunterNachmittags.state == 0) {
        mailActions.sendMail("emailaddress", "Rollladen geht runter auf 18", "Rollladen geht runter auf 18")
    } else if(nAzimut > 200 && nAzimut < 205 && VarHochRunterNachmittags.state == 1) {
        mailActions.sendMail("emailaddress", "Rollladen geht wieder auf", "Rollladen geht wieder auf")
And if VarHochRunterNachmittags is just an Item without any link to a channel, it’s very likely that .postUpdate(value) is the better and more direct method. A Switch Item would be even better for that purpose :wink:
Thank you all.
I think you helped me. My test worked. If it will work the next days I will post my finished code and will close this issue. I guess the biggest help was to replace by
Can you please replace my email. It was my mistake to leave them in. Thanks.
Oh, yes, sorry…
this code works perfect for me:
rule "Roller shutter down because of the light and in the afternoon up again"
   val nAzimut = (Lokale_Sonnendaten_Azimut.state as Number).floatValue
   val nHochRunter = VarHochRunterNachmittags.state as Number
   //Check of my holiday switch and the holiday switch for the roller shutters
   if(Urlaubsschalter.state == ON && UrlaubRollladenHochRunter.state == ON){
         //Check of the Azimut
         if(nHochRunter == 0 && nAzimut > 110 && nAzimut < 115){
             //Roller shutter half way down
         }else if(nHochRunter == 1 && nAzimut > 195 && nAzimut < 200){
            //Roller shutter up again
