Good day to all!
I have z-wave floor thermostat, raspberry z-wave controller and openhab 1.7.1. I installed need addons (binding, zwave, exec) and created item with bind, sitemap and persistance.
Item: Number Temp_kitchen_floor “Температура пола [%.1f °C]” { zwave=“8:command=sensor_multilevel,sensor_type=1” }
Persistance: Strategies {
default = everyChange
Items {
Temp_kitchen_floor : strategy = everyChange
Floor temperature is shown right. But once. On system start. Then it’s not update. When I create everyMinute strategy in exec persistance, I get error in log:
2015-11-20 16:08:37.066 [ERROR] [.o.p.exec.internal.ExecService] - Could not execute command [null]
at java.util.regex.Matcher.getTextLength(Matcher.java:1283) ~[na:1.8.0]
at java.util.regex.Matcher.reset(Matcher.java:309) ~[na:1.8.0]
at java.util.regex.Matcher.(Matcher.java:229) ~[na:1.8.0]
at java.util.regex.Pattern.matcher(Pattern.java:1093) ~[na:1.8.0]
at java.util.Formatter.parse(Formatter.java:2547) ~[na:1.8.0]
at java.util.Formatter.format(Formatter.java:2501) ~[na:1.8.0]
at java.util.Formatter.format(Formatter.java:2455) ~[na:1.8.0]
at java.lang.String.format(String.java:2925) ~[na:1.8.0]
at org.openhab.persistence.exec.internal.ExecService.formatAlias(ExecService.java:113) ~[na:na]
at org.openhab.persistence.exec.internal.ExecService.store(ExecService.java:49) ~[na:na]
at org.openhab.core.persistence.internal.PersistenceManager.handleStateEvent(PersistenceManager.java:240) [org.openhab.core.persistence_1.7.1.jar:na]
at org.openhab.core.persistence.internal.PersistenceManager.stateChanged(PersistenceManager.java:219) [org.openhab.core.persistence_1.7.1.jar:na]
at org.openhab.core.items.GenericItem.notifyListeners(GenericItem.java:112) [org.openhab.core_1.7.1.jar:na]
at org.openhab.core.items.GenericItem.setState(GenericItem.java:100) [org.openhab.core_1.7.1.jar:na]
at org.openhab.core.internal.items.ItemUpdater.receiveUpdate(ItemUpdater.java:71) [org.openhab.core_1.7.1.jar:na]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:38) [org.openhab.core_1.7.1.jar:na]
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
What I do wrong? Please, help me.
ps sorry for my worse english.
