Hello, I have a switch which I want to apply a timer to. When the switch receives ON (either through a cron job or manually, i.e. BasicUI) a 2 hour timer should start. When the 2 hours has passed the switch should receive OFF command.
The automatic ON command using cron jobs is working as expected, but I can’t get the automatic OFF command working.
If I manually send ON or OFF command from Basic UI the switch changes from ON to OFF or OFF to ON, so communication is working.
I’ve tried both Expire binding and Timer action without success.
My environment:
Rasperry Pi 3 Model B Plus Rev 1.3 with Z-wave.me RaZberry card
OpenHabian, Linux openhab 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l
OpenHAB 2.2.0-1
Java version 1.8.0_171
Expire binding (binding is installed and RPi restarted after installation):
Item definition
Switch TowelDryer "TowelDryer" <radiator> (Group1, Group2) { zwave="4", expire="30m,command=OFF"}
If I set the expire time to 10s, the OFF command is sent to the switch and it switches off as it should. This also works when I use 1m and 10m as expire time, but not with 30m, 60m, 120m, 2h… as expire time. Using expire times 30m or longer doesn’t send the command OFF to the switch. I haven’t yet exactly determined which the longest working expire time is.
When I add, change or remove the expire binding from the item definition I get an entry in the log file that says that the Expire Refresh Service has been started/shut down respectively.
Timer action in a rule:
I’ve also tried the timer action in a rule. When I send the command ON to the switch, manually from BasicIU or as a cron job, I get this error message in the log:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Timer Rule': An error occurred during the script execution: index=1, size=1
The item definition now looks like this:
The rules looks like this. It’s the third and last rule that contains the Timer action:
var Timer myTowelDryerTimer = null
rule "Morning rule"
Time cron "0 30 5 ? * *"
if (TowelDryer.state == OFF) {
TowelDryer.sendCommand(ON)
rule "Evening rule"
Time cron "0 0 20 ? * *"
if TowelDryer.state == OFF){
rule "Timer rule"
Item TowelDryer changed from OFF to ON
myTowelDryerTimer = createTimer(now.plusMinutes(120) [|
TowelDryer.sendCommand(OFF)
What can I do?
