I made a debug log for the fibaro FGCD-001 CO-Sensor. The related node is 82. I pushed the test button on the device an force to send the CO Alarm status. But the item does not change from NULL to anything. Hopefully the log helps.
temperature and battery is working fine, CO alarm and CO value not.
2019-02-22 19:20:45.757 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 52 02 84 07 20
2019-02-22 19:20:45.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:45.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:45.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:20:45.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2019-02-22 19:20:45.768 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:45.770 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Is awake with 0 messages in the queue
2019-02-22 19:20:45.771 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Start sleep timer at 1000ms
2019-02-22 19:20:45.772 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-02-22 19:20:45.789 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 82: Node Status event - Node is AWAKE
2019-02-22 19:20:45.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2019-02-22 19:20:45.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6afcbf.
2019-02-22 19:20:45.791 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:45.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:45.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:45.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:46.272 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:46.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:46.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: No more messages, go back to sleep
2019-02-22 19:20:46.776 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 82: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-02-22 19:20:46.778 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2019-02-22 19:20:46.779 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-02-22 19:20:46.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1fe760b
2019-02-22 19:20:46.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Bump transaction 16428 priority from Immediate to Immediate
2019-02-22 19:20:46.788 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2019-02-22 19:20:46.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 16428 to queue - size 40
2019-02-22 19:20:46.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:46.804 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 52 02 84 08 25 75 69
2019-02-22 19:20:46.809 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 09 00 13 52 02 84 08 25 75 69
2019-02-22 19:20:46.811 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-22 19:20:46.813 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-22 19:20:46.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.815 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:46.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:46.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-22 19:20:46.821 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-22 19:20:46.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:46.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:46.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:46.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:46.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:46.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.830 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:46.831 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2019-02-22 19:20:46.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16428: Advanced to WAIT_REQUEST
2019-02-22 19:20:46.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16428: Transaction not completed
2019-02-22 19:20:46.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:46.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:46.836 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 75 00 00 02 9C
2019-02-22 19:20:46.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=117, payload=75 00 00 02
2019-02-22 19:20:46.842 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=117, payload=75 00 00 02
2019-02-22 19:20:46.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16428: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:46.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16428: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.847 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 16428: (Callback 117)
2019-02-22 19:20:46.849 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-22 19:20:46.850 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 16428: callback 117
2019-02-22 19:20:46.851 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=117, payload=75 00 00 02
2019-02-22 19:20:46.853 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 117, Status = Transmission complete and ACK received(0)
2019-02-22 19:20:46.854 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:46.854 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 16428: Transaction COMPLETED
2019-02-22 19:20:46.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 42ms
2019-02-22 19:20:46.856 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16428: Transaction completed
2019-02-22 19:20:46.857 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:16428 DONE
2019-02-22 19:20:46.858 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-22 19:20:46.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:46.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16428: Transaction event listener: DONE: DONE ->
2019-02-22 19:20:46.860 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:46.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Went to sleep COMPLETE
2019-02-22 19:20:47.541 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 52 02 84 07 20
2019-02-22 19:20:47.544 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:47.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:47.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:20:47.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2019-02-22 19:20:47.548 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:47.549 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Is awake with 0 messages in the queue
2019-02-22 19:20:47.549 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Start sleep timer at 1000ms
2019-02-22 19:20:47.550 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-02-22 19:20:47.562 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 82: Node Status event - Node is AWAKE
2019-02-22 19:20:47.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2019-02-22 19:20:47.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@ee7bd4.
2019-02-22 19:20:47.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:47.565 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:47.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:47.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:48.051 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:48.551 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:48.553 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: No more messages, go back to sleep
2019-02-22 19:20:48.554 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 82: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-02-22 19:20:48.555 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2019-02-22 19:20:48.556 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-02-22 19:20:48.557 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@edae91
2019-02-22 19:20:48.559 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Bump transaction 16429 priority from Immediate to Immediate
2019-02-22 19:20:48.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2019-02-22 19:20:48.565 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 16429 to queue - size 40
2019-02-22 19:20:48.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:48.571 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 52 02 84 08 25 76 6A
2019-02-22 19:20:48.574 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 09 00 13 52 02 84 08 25 76 6A
2019-02-22 19:20:48.576 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-22 19:20:48.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.577 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-22 19:20:48.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:48.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:48.582 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.583 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-22 19:20:48.584 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:48.585 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-22 19:20:48.585 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:48.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:48.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:48.590 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:48.592 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.593 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:48.593 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2019-02-22 19:20:48.594 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16429: Advanced to WAIT_REQUEST
2019-02-22 19:20:48.594 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16429: Transaction not completed
2019-02-22 19:20:48.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:48.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:48.600 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 76 00 00 03 9E
2019-02-22 19:20:48.602 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=118, payload=76 00 00 03
2019-02-22 19:20:48.603 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=118, payload=76 00 00 03
2019-02-22 19:20:48.603 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16429: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.604 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:48.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16429: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 16429: (Callback 118)
2019-02-22 19:20:48.606 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-22 19:20:48.606 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 16429: callback 118
2019-02-22 19:20:48.607 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=118, payload=76 00 00 03
2019-02-22 19:20:48.608 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 118, Status = Transmission complete and ACK received(0)
2019-02-22 19:20:48.609 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:48.609 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 16429: Transaction COMPLETED
2019-02-22 19:20:48.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 33ms
2019-02-22 19:20:48.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16429: Transaction completed
2019-02-22 19:20:48.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:16429 DONE
2019-02-22 19:20:48.612 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-22 19:20:48.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:48.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16429: Transaction event listener: DONE: DONE ->
2019-02-22 19:20:48.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:48.613 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Went to sleep COMPLETE
2019-02-22 19:20:49.225 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 52 02 84 07 20
2019-02-22 19:20:49.228 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:49.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:49.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:20:49.232 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2019-02-22 19:20:49.233 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:49.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Is awake with 0 messages in the queue
2019-02-22 19:20:49.236 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Start sleep timer at 1000ms
2019-02-22 19:20:49.237 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-02-22 19:20:49.254 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 82: Node Status event - Node is AWAKE
2019-02-22 19:20:49.254 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2019-02-22 19:20:49.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1bfcf2a.
2019-02-22 19:20:49.256 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:49.257 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:49.257 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:49.738 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:50.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:50.241 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: No more messages, go back to sleep
2019-02-22 19:20:50.242 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 82: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-02-22 19:20:50.243 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2019-02-22 19:20:50.243 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-02-22 19:20:50.244 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@135eb07
2019-02-22 19:20:50.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Bump transaction 16430 priority from Immediate to Immediate
2019-02-22 19:20:50.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2019-02-22 19:20:50.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 16430 to queue - size 40
2019-02-22 19:20:50.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:50.249 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 52 02 84 08 25 77 6B
2019-02-22 19:20:50.251 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 09 00 13 52 02 84 08 25 77 6B
2019-02-22 19:20:50.252 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-22 19:20:50.253 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.253 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-22 19:20:50.254 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:50.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:50.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.256 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-22 19:20:50.256 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:50.257 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:50.260 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-22 19:20:50.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:50.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:50.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:50.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.266 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:50.267 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2019-02-22 19:20:50.267 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16430: Advanced to WAIT_REQUEST
2019-02-22 19:20:50.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16430: Transaction not completed
2019-02-22 19:20:50.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:50.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:50.277 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 77 00 00 02 9E
2019-02-22 19:20:50.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=119, payload=77 00 00 02
2019-02-22 19:20:50.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=119, payload=77 00 00 02
2019-02-22 19:20:50.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16430: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:50.282 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16430: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 16430: (Callback 119)
2019-02-22 19:20:50.284 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-22 19:20:50.285 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 16430: callback 119
2019-02-22 19:20:50.286 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=119, payload=77 00 00 02
2019-02-22 19:20:50.287 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 119, Status = Transmission complete and ACK received(0)
2019-02-22 19:20:50.288 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:50.288 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 16430: Transaction COMPLETED
2019-02-22 19:20:50.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 37ms
2019-02-22 19:20:50.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16430: Transaction completed
2019-02-22 19:20:50.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:16430 DONE
2019-02-22 19:20:50.293 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-22 19:20:50.294 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:50.294 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:50.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16430: Transaction event listener: DONE: DONE ->
2019-02-22 19:20:50.300 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Went to sleep COMPLETE
2019-02-22 19:21:06.766 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 4D 04 30 03 00 0C 87
2019-02-22 19:21:06.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=77, callback=0, payload=00 4D 04 30 03 00 0C
2019-02-22 19:21:06.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=77, callback=0, payload=00 4D 04 30 03 00 0C
2019-02-22 19:21:06.771 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:21:06.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 77: Application Command Request (ALIVE:DONE)
2019-02-22 19:21:06.773 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 77: resetResendCount initComplete=true isDead=false
2019-02-22 19:21:06.773 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 77: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2019-02-22 19:21:06.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 77: SECURITY NOT required on COMMAND_CLASS_SENSOR_BINARY
2019-02-22 19:21:06.774 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 77: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2019-02-22 19:21:06.775 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 12
2019-02-22 19:21:06.776 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is MOTION
2019-02-22 19:21:06.776 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 77: Sensor Binary report, type=Motion, value=0
2019-02-22 19:21:06.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 77: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2019-02-22 19:21:06.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 77: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_BINARY, value = 0
2019-02-22 19:21:06.779 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 77: Updating channel state zwave:device:15a7a49f3a6:node77:sensor_binary to OFF [OnOffType]
2019-02-22 19:21:06.780 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 77: Commands processed 1.
2019-02-22 19:21:06.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 77: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@56c77c.
2019-02-22 19:21:06.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:21:06.783 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:21:06.784 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
