Thanks - that’s fine. I think it gets reformatted at some point, but that’s what I was after.
It’s a new enough firmware version (but not super new - probably a couple of years old). The HZUSB-1 sticks that many people are using have firmware version 5.4 if I remember correctly and that also works fine.
I just looked at this log - are you continually resetting the device?
In this log, it looks like the device starts to join. It announces itself on the network, and the binding starts to discover it. Then it announces itself again with a different address - this normally means it has been reset. Then it announces again with a different address - this happens a number of times -:
I did not touch the dongle settings if this is what you are referring to. Neither in 2.4, nor in 2.5.
As mentioned above, I made two pairing attempts. Since the lamp hasn’t been paired yet, it seems to go through the same steps as when resetting it after turning it on (it’s cycling through a couple of colors). Probably, this is what is causing the address changes.
Since the log included three different addresses, I guess I was too impatient during one discovery attempt. I remember the lamp didn’t show up at first, so I probably turned it off and on again, because I thought it would only go into pairing mode then.
I can provide a log with just a single attempt if this is off any help.
Here is a log of the successful pairing from OpenHab 2.4 (used the other lamp 00158D0001FDF3BD this time, but it’s the same for both): openhab_2.4.log (623.6 KB)
Once I get the development environment working I will migrate the binding to the latest libraries. These are already in use by Deutche Telekom (who also use the binding) so hopefully that will help. I can’t really work on the 2.4 binding as it’s really very very old now - sorry.
The OpenHab 2.4 log I posted above was just for reference to check how a successful pairing between the mentioned dongle and lamp looks like.
Once your dev environment is ready, I can help testing if necessary. I have a spare OpenHab 2.5 installation I can use for that without breaking my main OpenHab system.
So I tried this out
I upgraded my system to openhab 2.5 stable, uninstalled zigbee binding and manually installed the above versions of binding and libraries. With this setup, my existing zigbee network seems to work fine, and I could successfully pair one Osram Smart Plug which I had removed previously.
But when trying to pair more devices (even an identical Osram Smart Plug), I just end up with “Unknown Zigbee Devices”. I took a debug log, here’s what the debug log includes:
Put Zigbee Binding in discovery mode
Reset Osram Smart Plug (7CB03EAA0A02AF24)
(wait some time)
Reset Xiaomi Temperature and Humidity Sensor (00158D00032170C3)
(wait some time)
Put Zigbee binding in discovery mode
Reset Xiaomi Aqara Wireless Mini Switch (00158D000204B50B)
(wait some time)
Log file is a .zip-file, please rename to .zip: openhab.txt (91.0 KB)
After this procedure, all devices are still listed in the inbox as “Unknown Zigbee Device”. I know the Xiaomi devices can be problematic, but at least the Osram Plug shouldn’t be. And I used all these devices successfully with my previous system (cc2531, openhab 2.5 M2), and also successfully paired them quite often.
Strange - it is working fine here, and I have other users I support with the latest binding where it is also working fine. We also just completed a ZigBee certification this week for a system based on this.
I’m using it here with Osram bulbs, Ikea bulbs and a number of other devices.
I will try and take a look at the log when I get a chance.
