Just upgraded my system from 2.4 to 2.5.7. Most issues resolved. One persists, however. The GlobalCache binding it throwing an error.
I’ve un-installed and re-installed the binding. I’ve un-installed and re-installed the Map Transformation. I’ve stopped the service, cleared the cache, and restarted the service. I’ve rebooted the server.
Log entry:
2020-07-26 10:29:45.258 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.globalcache.handler.GlobalCacheHandler@1078613’: bundleContext
java.lang.NoSuchFieldError: bundleContext
at org.openhab.binding.globalcache.handler.GlobalCacheHandler.lookupCode(GlobalCacheHandler.java:196) ~[?:?]
at org.openhab.binding.globalcache.handler.GlobalCacheHandler.handleInfrared(GlobalCacheHandler.java:151) ~[?:?]
at org.openhab.binding.globalcache.handler.GlobalCacheHandler.handleCommand(GlobalCacheHandler.java:126) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_201]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_201]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_201]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_201]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy389.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_201]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_201]
