same problem with the HM-MOD_EM-8. I use the last OH3 from stable repro. It is running in an Proxmox 6 Buster VM. I stopped OH3 and cleaned cache. This is my openhab.log
`2021-01-26 13:23:00.459 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2021-01-26 13:23:06.905 [WARN ] [.transport.servlet.ServletController] - Can’t find the request for http://192.168.1.119:8080/rest/items’s Observer
2021-01-26 13:23:10.563 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2021-01-26 13:23:10.572 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘51.49219903394707’.
2021-01-26 13:23:10.576 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2021-01-26 13:23:10.580 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to ‘SI’.
2021-01-26 13:23:15.145 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘influxdb.persist’
2021-01-26 13:23:18.771 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Schreibtischlampe.rules’
2021-01-26 13:23:21.079 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Erdkugel.rules’
2021-01-26 13:23:24.945 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state ‘NULL’ on item ‘GartenHausTuer’ with pattern ‘MAP(de.map):%s’: Couldn’t transform value because transformation service of type ‘MAP’ is not available.
2021-01-26 13:23:26.358 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-01-26 13:23:29.814 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-01-26 13:24:56.585 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing ‘http:url:a98cd708a8’.
2021-01-26 13:24:56.626 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing ‘http:url:6b99950337’.
2021-01-26 13:24:57.681 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2021-01-26 13:24:58.547 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = eac, base URL = http://localhost:8080)
2021-01-26 13:25:48.897 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘754cdcb948’ not available, disabling support
2021-01-26 13:25:48.899 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘3014F711A0001F58A992F3B3’ not available, disabling support
2021-01-26 13:25:49.036 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.55.5.62,address=PEQ0625587,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2021-01-26 13:25:49.043 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.55.5.62,address=PEQ0625587,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2021-01-26 13:26:09.512 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:754cdcb948:OEQ0226894’ to inbox.
2021-01-26 13:26:09.971 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-ES-PMSw1-Pl:754cdcb948:MEQ0170613’ to inbox.
2021-01-26 13:26:10.166 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-MDIR-WM55:754cdcb948:MEQ1849960’ to inbox.
2021-01-26 13:26:10.340 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-DB-PCB:754cdcb948:MEQ0044639’ to inbox.
2021-01-26 13:26:10.435 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw4-PCB:754cdcb948:MEQ0022409’ to inbox.
2021-01-26 13:26:10.535 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-RGBW-WM:754cdcb948:MEQ1782462’ to inbox.
2021-01-26 13:26:10.592 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-WDS40-TH-I:754cdcb948:RALLE0I005’ to inbox.
2021-01-26 13:26:10.602 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-ES-PMSw1-Pl:754cdcb948:LEQ1276011’ to inbox.
2021-01-26 13:26:10.608 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-WDS40-TH-I:754cdcb948:RALLE0I004’ to inbox.
2021-01-26 13:26:10.713 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw4-Ba-PCB:754cdcb948:LEQ1185506’ to inbox.
2021-01-26 13:26:10.721 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw1PBU-FM:754cdcb948:LEQ1016017’ to inbox.
2021-01-26 13:26:10.807 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-PB-2-WM55:754cdcb948:OEQ0484194’ to inbox.
2021-01-26 13:26:10.815 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:754cdcb948:MEQ0288461’ to inbox.
2021-01-26 13:26:10.866 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw1PBU-FM:754cdcb948:LEQ1014958’ to inbox.
2021-01-26 13:26:11.127 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SD:754cdcb948:LEQ0726017’ to inbox.
2021-01-26 13:26:11.138 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘Hoehe ueber NN’ contains invalid characters, new Datapoint name ‘Hoehe_ueber_NN’
2021-01-26 13:26:11.181 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HB-UNI-Sensor1:754cdcb948:UNISENS001’ to inbox.
2021-01-26 13:26:11.447 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-SCI-3-FM:754cdcb948:LEQ1455011’ to inbox.
2021-01-26 13:26:11.502 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw1-Ba-PCB:754cdcb948:20200624_1’ to inbox.
2021-01-26 13:26:11.512 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-SCI-3-FM:754cdcb948:LEQ1455492’ to inbox.
2021-01-26 13:26:11.600 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Dim1TPBU-FM:754cdcb948:QEQ0342278’ to inbox.
2021-01-26 13:26:11.746 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:754cdcb948:MEQ0288690’ to inbox.
2021-01-26 13:26:11.849 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-4-3:754cdcb948:OEQ0326085’ to inbox.
2021-01-26 13:26:12.041 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-MDIR-WM55:754cdcb948:OEQ0539735’ to inbox.
2021-01-26 13:26:12.047 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SD:754cdcb948:LEQ0648697’ to inbox.
2021-01-26 13:26:12.149 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:754cdcb948:MEQ0034424’ to inbox.
2021-01-26 13:26:12.295 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HB-UNI-SenAct-4-4-SC:754cdcb948:JPSENACT10’ to inbox.
2021-01-26 13:26:12.337 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-4-3:754cdcb948:OEQ0327045’ to inbox.
2021-01-26 13:26:12.343 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-4-3:754cdcb948:OEQ0326470’ to inbox.
2021-01-26 13:26:12.351 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-WDS40-TH-I:754cdcb948:RALLE02007’ to inbox.
2021-01-26 13:26:12.409 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-PB-2-WM55:754cdcb948:NAA0002928’ to inbox.
2021-01-26 13:26:12.653 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Dis-WM55:754cdcb948:LEQ1323178’ to inbox.
2021-01-26 13:26:13.042 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-SWD:754cdcb948:001898A9A3693F’ to inbox.
2021-01-26 13:26:13.783 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-RCV-50:754cdcb948:HmIP-RCV-1’ to inbox.
2021-01-26 13:26:14.684 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-WRC6:754cdcb948:000B5709AF3D1E’ to inbox.
2021-01-26 13:26:14.694 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-FROLL:754cdcb948:001158A991389E’ to inbox.
2021-01-26 13:26:14.887 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-19:754cdcb948:CUX2801001’ to inbox.
2021-01-26 13:26:14.930 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘HB-RF-ETH Connection’ contains invalid characters, new Datapoint name ‘HB-RF-ETH_Connection’
2021-01-26 13:26:14.998 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:GATEWAY-EXTRAS-754CDCB948:754cdcb948:GWE00000000’ to inbox.
2021-01-26 13:26:15.000 [INFO ] [rnal.type.HomematicTypeGeneratorImpl] - Multiple firmware versions for device type ‘HM-LC-Sw1-FM’ found (1.12, 2.8). Make sure, all devices of the same type have the same firmware version, otherwise you MAY have channel and/or datapoint errors in the logfile
2021-01-26 13:27:25.118 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘3014F711A0001F58A992F3B3’ not available, disabling support
2021-01-26 13:27:25.147 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.55.5.62,address=PEQ0625587,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2021-01-26 13:27:29.877 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 3, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.888 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 4, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.898 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 5, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.909 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 6, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.918 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 7, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.931 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 8, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.940 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 9, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:29.950 [INFO ] [ommunicator.AbstractHomematicGateway] - Can not load values for device: LEQ1323178, channel: 10, paramset: VALUES, maybe there are no values available
2021-01-26 13:27:35.695 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HB-UNI-SenAct-4-4-RC:3014F711A0001F58A992F3B3:JPSENACT02’ to inbox.
2021-01-26 13:27:35.712 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HB-UNI-SenAct-4-4-RC:3014F711A0001F58A992F3B3:JPSENACT01’ to inbox.
2021-01-26 13:27:35.814 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-Key4-3:3014F711A0001F58A992F3B3:OEQ0899518’ to inbox.
2021-01-26 13:27:35.951 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw1PBU-FM:3014F711A0001F58A992F3B3:MEQ0992224’ to inbox.
2021-01-26 13:27:36.024 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:MEQ1659435’ to inbox.
2021-01-26 13:27:36.058 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RCV-50:3014F711A0001F58A992F3B3:BidCoS-RF’ to inbox.
2021-01-26 13:27:36.093 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-DB-PCB:3014F711A0001F58A992F3B3:MEQ0044639’ to inbox.
2021-01-26 13:27:36.257 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:OEQ0702791’ to inbox.
2021-01-26 13:27:36.263 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:OEQ0703560’ to inbox.
2021-01-26 13:27:36.548 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-MDIR-O:3014F711A0001F58A992F3B3:LEQ0612403’ to inbox.
2021-01-26 13:27:36.603 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw1-FM:3014F711A0001F58A992F3B3:LEQ0590094’ to inbox.
2021-01-26 13:27:36.747 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-MOD-EM-8:3014F711A0001F58A992F3B3:OEQ0175703’ to inbox.
2021-01-26 13:27:36.778 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SD:3014F711A0001F58A992F3B3:LEQ0648760’ to inbox.
2021-01-26 13:27:36.798 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘Hoehe ueber NN’ contains invalid characters, new Datapoint name ‘Hoehe_ueber_NN’
2021-01-26 13:27:36.839 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-MDIR-WM55:3014F711A0001F58A992F3B3:MEQ1849872’ to inbox.
2021-01-26 13:27:36.948 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-8:3014F711A0001F58A992F3B3:LEQ0807489’ to inbox.
2021-01-26 13:27:36.977 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SC-2:3014F711A0001F58A992F3B3:LEQ0404437’ to inbox.
2021-01-26 13:27:37.083 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-SCI-3-FM:3014F711A0001F58A992F3B3:LEQ1455492’ to inbox.
2021-01-26 13:27:37.241 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-PB-6-WM55:3014F711A0001F58A992F3B3:LEQ0636224’ to inbox.
2021-01-26 13:27:37.247 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:OEQ0226910’ to inbox.
2021-01-26 13:27:37.265 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SD:3014F711A0001F58A992F3B3:LEQ0648011’ to inbox.
2021-01-26 13:27:37.270 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-MDIR-O:3014F711A0001F58A992F3B3:MEQ0247068’ to inbox.
2021-01-26 13:27:37.281 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-ES-PMSw1-Pl:3014F711A0001F58A992F3B3:LEQ0574050’ to inbox.
2021-01-26 13:27:37.421 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Bl1PBU-FM:3014F711A0001F58A992F3B3:NEQ0048594’ to inbox.
2021-01-26 13:27:37.430 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-ES-PMSw1-Pl:3014F711A0001F58A992F3B3:OEQ0769918’ to inbox.
2021-01-26 13:27:37.439 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:MEQ1657993’ to inbox.
2021-01-26 13:27:37.544 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-MOD-EM-8:3014F711A0001F58A992F3B3:OEQ0176371’ to inbox.
2021-01-26 13:27:37.549 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:OEQ0226909’ to inbox.
2021-01-26 13:27:37.620 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SD-Team:3014F711A0001F58A992F3B3:T-LEQ0726017’ to inbox.
2021-01-26 13:27:37.627 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:MEQ1658806’ to inbox.
2021-01-26 13:27:37.654 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-OU-CM-PCB:3014F711A0001F58A992F3B3:LEQ1184912’ to inbox.
2021-01-26 13:27:37.661 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-ES-PMSw1-Pl:3014F711A0001F58A992F3B3:LEQ1275740’ to inbox.
2021-01-26 13:27:37.883 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-Key:3014F711A0001F58A992F3B3:OEQ0898772’ to inbox.
2021-01-26 13:27:38.021 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-LC-Sw1-FM:3014F711A0001F58A992F3B3:OEQ1150485’ to inbox.
2021-01-26 13:27:38.028 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sen-MDIR-WM55:3014F711A0001F58A992F3B3:MEQ1849897’ to inbox.
2021-01-26 13:27:38.215 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Dis-WM55:3014F711A0001F58A992F3B3:LEQ1323178’ to inbox.
2021-01-26 13:27:38.221 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-Sec-SCo:3014F711A0001F58A992F3B3:MEQ1658818’ to inbox.
2021-01-26 13:27:38.266 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-2-PBU-FM:3014F711A0001F58A992F3B3:NEQ1319054’ to inbox.
2021-01-26 13:27:38.272 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-SCI-3-FM:3014F711A0001F58A992F3B3:LEQ1455072’ to inbox.
2021-01-26 13:27:38.477 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-FROLL:3014F711A0001F58A992F3B3:001158A991381C’ to inbox.
2021-01-26 13:27:40.035 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-MOD-OC8:3014F711A0001F58A992F3B3:000D18A9A5AB34’ to inbox.
2021-01-26 13:27:40.256 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-SRH:3014F711A0001F58A992F3B3:0007DA498E93DC’ to inbox.
2021-01-26 13:27:40.267 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-FROLL:3014F711A0001F58A992F3B3:001158A991387F’ to inbox.
2021-01-26 13:27:40.343 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RC-19:3014F711A0001F58A992F3B3:CUX2801001’ to inbox.
2021-01-26 13:27:40.367 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘HB-RF-ETH Connection’ contains invalid characters, new Datapoint name ‘HB-RF-ETH_Connection’
2021-01-26 13:27:40.402 [INFO ] [rnal.type.HomematicTypeGeneratorImpl] - Multiple firmware versions for device type ‘HM-LC-Sw1-FM’ found (1.12, 2.8). Make sure, all devices of the same type have the same firmware version, otherwise you MAY have channel and/or datapoint errors in the logfile
2021-01-26 13:30:00.219 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘HB-RF-ETH Connection’ contains invalid characters, new Datapoint name ‘HB-RF-ETH_Connection’
I can not see any problem
your code goes here
