chubv
(Chris)
February 22, 2016, 8:06pm
#1
Hi!
I’m running openHAB2 with homematic.
I’ve a water sensor HM-SEC-WDS-2.
My problem is that there are only two states for it in openHAB.
CLOSED=dry
OPEN=wet
I’m missing the third state which should be “damp”.
I found a small wiki with a short description for the sensor:
https://code.google.com/archive/p/openhab-homematic/wikis/SupportedDevices.wiki
Is it possible to get the states 0, 1 and 2 instead of CLOSED and OPEN?
Thanks for your help!
AWi
(Andre)
March 30, 2017, 8:17am
#2
If you use the item type “String” you get the values “DRY”, “WET” and “WATER”.
My item type definition is as follows
String kitchenWaterSensor "Wasserstand [%s]" (watersensors, locationKitchen) { channel="homematic:HM-Sec-WDS-2:CHANNEL#STATE" }
regards, andré
Tomme
(Tomme)
January 7, 2018, 3:14pm
#3
Have you repalced CHANNEL with a channel number or is that line copy-pasted directly from your config?
I am asking because I have problems receiving the STATE of both of my HM-SEC-WDS-2. Regardless of the item type I choose, the state change ist not being published from my CCU2 to Openhab2.
AWi
(Andre)
January 14, 2018, 9:26pm
#4
The line is directly copied from my config. What I deleted is the name of the device. I typically copy the channel from the Paper UI
"channel=“homematic:HM-Sec-WDS-2:xyz:zyq:1#STATE”
