I’m integrating OA with Zoneminder using Zoneminder’s REST API.
I need to check detection status, and switch motion detection ON and OFF reflecting the status of antitheft.
To turn ON and OFF motion detection i need to all the API in POST passing one parameter. I configured like this:
Unfortunately, the HTTP binding does not pass data in the body of the message when using the POST method. Your curl command is doing so with the -d parameter, but in your item binding string, the data is being passed as part of the URL, which the receiving end is not accepting. I think your alternative may be to use the exec binding instead of the HTTP binding and call curl to perform the HTTP POST for you.
Hi watou and thanks for explanation.
I have another question. Is possible to mix on a single Item 2 bindings?
I would like to use HTTP to retrieve values and EXEC to send command.
Thanks and regards
Yes, this works. I know of a user that has a single item that reads from his Ecobee thermostat and writes the returned temperature to an MQTT broker, all within the single item line. The syntax is { thisbinding="…", thatbinding="…" }
Http part is working, but seems exec part not. It seems command in not fired. Is there any traces in the logs of this Exec? And what i should looking for?
Encountered the same issue and also switched to the exec binding to call curl to work around it. Would be helpful when the wiki page of the http binding is updated describing this limitation and possible workaround. Wasted hours trying to get the config right…
It is currently not possible to send a message body, as one might do typically with the POST HTTP method. An alternative solution, in the case where the receiving web server requires a message body, might be to execute curl ... -d <data> using the [[exec binding|exec-Binding]].
I’ve never seen an example of it, and without knowing for sure it seems doubtful that those inner workings are easily accessed. (Happy to be proven wrong.)
John,
You can also do it directly in a rule, using sendHttpPostRequest. This was missing from the Actions Wiki page, so I added it in, along with a few other variants from the original source.
This is handy if you want to write POST calls at higher frequency, since you can avoid launching child processes.
The downside is that these versions don’t allow headers to be passed in. The underlying HttpUtils class does, but there’s not currently a wrapper version for it (fairly trivial to add, but v1’s sorta on lockdown)
I am a new openHAB user. Just installed it yesterday on a BeagleBoneBlack. I was using X10 and Heyu to control my home but I just bought a SmartPlug, used it to control my CoffeeMaker and hacked it so that it would respond to “http://coffee/cgi-bin/relay.cgi?on” or off or state. I think that for IoT, Wifi is the future.
So I used the demo house and modified one item: Switch Light_GF_Kitchen_Table "Coffee Maker" (GF_Kitchen) {http=">[ON:GET:http://cafe/cgi-bin/relay.cgi?on] >[OFF:GET:http://cafe/cgi-bin/relay.cgi?off] <[http://cafe/cgi-bin/relay.cgi?state:5000:REGEX(O.*)]"}This works fine to control the coffee maker but does not work to read the current state if I turn it on or off locally.
I tried the url in my browser: http://cafe/cgi-bin/relay.cgi?state
and the reply comes back ON\n or OFF\n.
I don’t know what the reply should be. I don’t know if mapping the output is necessary. If not, I don’t know if I still need the “:” after the 5000 ms.
I have full control over the reply. I can make it whatever I want. But there is no documentation as to what is expected for the different types of objects. What is valid. Should it be ON or OFF or on or off or 1 or 0?
